.NET
Valued Contributor
bert.vanpeteghem
Message 11 of 15 (334 Views)
Re: Multiple acdbmgd & acmgd references?
03-27-2009 12:34 AM in reply to: *C Witt
good thinking on using extension methods for version compatibility...
I've been using the #if conditional directive, and then build with different constants defined, according to versions... Works too, but I like this solution a lot more!
Time to review some of my code :smileyhappy:
*Terry W. Dotson
Message 12 of 15 (334 Views)
03-27-2009 06:45 AM in reply to: *C Witt
Tony Tanzillo wrote:
> Rather than branching once when the code loads, your so-called
> solution branches every single time the property's value is needed.
The example was when I first discovered the alternative, and was not
intended to be optimized. I later changed it to preset the string
variable on loading to avoid the branches.
CallByName(AddEnt, StyPrp, CallType.Set, StyRec.ObjectId)
What is "astounding" is that it took you almost 24 hours to criticize.
Terry
*Tony Tanzillo
Message 13 of 15 (334 Views)
03-27-2009 02:15 PM in reply to: *C Witt
Nothing astounding about that, it's a side-effect of being busy.
{quote}
{quote}
Duh.
It still isn't 'optimized'.
Perhaps if you better understood the API you're using, you might understand
why there is a difference between caching a property name in a string, and
caching the PropertyInfo object returned by the reflection search for the
name.
Unfortunately I have other things things to do and can't really afford to
take the time to tutor you in the finer points of using reflection or
late-binding overhead, but feel free to visit the Microsoft newsgroups and
ask them to tell you more about it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Terry W. Dotson" wrote in message
news:6150674@discussion.autodesk.com...
*Terry W. Dotson
Message 14 of 15 (334 Views)
03-27-2009 03:09 PM in reply to: *C Witt
> ... can't really afford to take the time to tutor you ...
All well and good as I didn't ask for (or need) your help.
Terry
Valued Mentor
AubelecBE
Message 15 of 15 (173 Views)
02-27-2012 04:26 AM in reply to: *Tony Tanzillo
Hi. can you explain how to use you code in VS2010 express? (If i can.) I have many acad version 2009, 2010 and 2012
I dont know how to manage all this version... I want  build only one DDL (if i can).
I dont know how to manage VS2010 exp for not check a part of my code.
My think :
Try
'v autocad 2010
  DBTexte.TextStyleID =....
catch ex as exception
'v autocad 2009
  DBTexte.TextStyle = ...
end try.
if a build with dll from autocad 2009 i have error for .TextStyleId and for autocad 2010 .textStyle
so ....
Thx
