.NET
.NET
*C Witt
Post 1 of 15
Multiple acdbmgd & acmgd references?
535 Views, 14 Replies
01-19-2009 01:54 PM
Is it possible to reference more than one version of these files in a
single project?
The reason I ask is that the 2 version of AutoCAD we are using have
different "properties" for the objects in question (the names change)...
Work: VISTA Ultimate x32 - AMD 64 X2
Dual Core 4200 2.2GHz, 4 Gigs Ram, GeForce
6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad
Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 -
color="#000000">AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram,
color="#666666">Nvidia GeForce 6150
*Tony Tanzillo
Post 2 of 15
Re: Multiple acdbmgd & acmgd references?
01-19-2009 02:34 PM in reply to: *C Witt
No, you can't do that.
What properties are changed?
"C Witt" wrote in message
news:6107669@discussion.autodesk.com...
Is it possible to reference more than one version of these files in a single
project?
Work: VISTA Ultimate x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs Ram,
GeForce 6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad Core 2.2GHz, 8 Gigs Ram, GeForce
8600GT 512MB
Laptop (17" HP): VISTA Premium x32 - AMD Turion X2 Dual Core TL-50 1.6GHz, 2
Gigs Ram, Nvidia GeForce 6150
*C Witt
Post 3 of 15
01-19-2009 03:22 PM in reply to: *C Witt
The textstyle property of the text object changed from "textstyle" to
"textstyleid"...
Work: VISTA
color="#666666">GeForce 6800GS 256MB
"C Witt" <cwitt_AT_trkeng.com> wrote in message
project?
*Tony Tanzillo
Post 4 of 15
01-19-2009 09:03 PM in reply to: *C Witt
Are you using Visual Studio 2008 ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
news:6107734@discussion.autodesk.com...
"textstyleid"...
8600GT 512MB
project?
*C Witt
Post 5 of 15
01-20-2009 08:42 AM in reply to: *C Witt
yes
Work: VISTA
Ultimate/Windows 7 x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs
Ram, GeForce 6800GS 256MB
*Tony Tanzillo
Post 6 of 15
01-20-2009 09:11 AM in reply to: *C Witt
The only option would be to use reflection.
The class below defines two extension methods for
DBText and MText that can be used in either release:
You use them just like they were methods of the
DBText and MText objects:
ObjectId GetTextStyleId();
void SetTextStyleId( ObjectId value );
[code]
{code}
public static class VersionCompatibleExtensionMethods
public static ObjectId GetTextStyleId( this DBText instance )
if( textStyleProperty != null )
return (ObjectId) textStyleProperty.GetValue( instance, null );
else
throw new MissingMemberException();
public static ObjectId GetTextStyleId( this MText instance )
if( mtextStyleProperty != null )
return (ObjectId) mtextStyleProperty.GetValue( instance, null );
else
public static void SetTextStyleId( this DBText instance, ObjectId value )
textStyleProperty.SetValue( instance, value, null );
else
public static void SetTextStyleId( this MText instance, ObjectId value )
mtextStyleProperty.SetValue( instance, value, null );
else
static VersionCompatibleExtensionMethods()
textStyleProperty = typeof( DBText ).GetProperty( "TextStyle" );
if( textStyleProperty == null )
textStyleProperty = typeof( DBText ).GetProperty( "TextStyleId" );
mtextStyleProperty = typeof( DBText ).GetProperty( "TextStyle" );
if( mtextStyleProperty == null )
mtextStyleProperty = typeof( DBText ).GetProperty( "TextStyleId" );
private static PropertyInfo textStyleProperty = null;
private static PropertyInfo mtextStyleProperty = null;
{code}
[/code]
news:6108204@discussion.autodesk.com...
yes
Work: VISTA Ultimate/Windows 7 x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs
8600GT 512MB
*C Witt
Post 7 of 15
01-20-2009 10:15 AM in reply to: *C Witt
Thank you Tony, I will give that a shot!
Work: VISTA
[code]
<code>
{code}
else
else
else
else
{code}
</code>
[/code]
*Terry W. Dotson
Post 8 of 15
03-26-2009 12:50 PM in reply to: *C Witt
> "textstyleid"...
If you are using VB on VS2005 and need to support 2007 then this appears
to work.
If AcdApp.Version = 17.0 Then
CallByName(AddEnt, "TextStyle", CallType.Set, StyRec.ObjectId)
Else
CallByName(AddEnt, "TextStyleId", CallType.Set, StyRec.ObjectId)
End If
Terry
*Tony Tanzillo
Post 9 of 15
03-26-2009 07:07 PM in reply to: *C Witt
Rather than branching once when the code loads, your so-called
solution branches every single time the property's value is needed.
Astounding.
"Terry W. Dotson" wrote in message
news:6150151@discussion.autodesk.com...
> "textstyleid"...
to work.
Else
End If
Terry
*Tony Tanzillo
Post 10 of 15
03-26-2009 07:12 PM in reply to: *C Witt
For those that use VS2005, you can still use the code posted
as extension methods, by just converting them to plain old
static methods (non-extension methods), and passing the
DBText or MText objects to them as the first parameter. Just
remove the 'this' from first parameter declaration.
"Tony Tanzillo" wrote in message
news:6108262@discussion.autodesk.com...
[code]
{code}
else
else
else
else
{code}
[/code]
yes
8600GT 512MB
