.NET
9 Kudos
Post 1 of 11
Multileader scale
1516 Views, 10 Replies
03-21-2011 01:17 AM
Does anyone know how to set the overall scale of a multileader? I have set the .Scale property, but that seems to have done nothing.
                MleaderStyle.Annotative = AnnotativeStates.False
                MleaderStyle.LeaderLineType = LeaderType.StraightLeader
                MleaderStyle.ArrowSize = Me.ArrowHeadSize
                MleaderStyle.BreakSize = Me.DimensionBreak
                MleaderStyle.DoglegLength = Me.LandingLength
                MleaderStyle.EnableLanding = True
                MleaderStyle.EnableDogleg = True
                MleaderStyle.EnableFrameText = False
                MleaderStyle.LandingGap = 2
                MleaderStyle.MaxLeaderSegmentsPoints = 50
                MleaderStyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst
                MleaderStyle.LeaderLineColor = Me.LeaderColour
                '' Text Settings
                MleaderStyle.ContentType = Autodesk.AutoCAD.DatabaseServices.ContentType.MTextContent
                MleaderStyle.TextHeight = 2.5
                MleaderStyle.TextAlignAlwaysLeft = True
                MleaderStyle.TextAttachmentType = TextAttachmentType.AttachmentMiddleOfTop
                MleaderStyle.TextAlignmentType = TextAlignmentType.LeftAlignment
                MleaderStyle.TextColor = Color.FromColorIndex(ColorMethod.ByPen, CShort(Project.DimensionTextColour))
                MleaderStyle.Scale = 50
                MleaderStyle.PostMLeaderStyleToDb(db, "50m")
                tr.AddNewlyCreatedDBObject(MleaderStyle, True)
Everything else works, but the overall scale is always 1.
To change the scale of the actual mleader mleader I do not think there is a way .Net with exception of PInvoke.
see http://www.theswamp.org/index.php?topic=31861.msg386494#msg386494
The scale the code is setting is for style which should effect all mleaders on that style, but for indivdual mleaders scale property see link.
If that helps at all are if that is what you are after.
Valued Mentor
13 Kudos
Post 2 of 11
Re: Multileader scale
03-23-2011 04:46 PM in reply to: BrentBurgess1980
Is your code changing an actual instance of a MleaderStyle?
Something Like?
MLeaderStyle mlStyle = dbentry.GetObject(OpenMode.ForWrite) as MLeaderStyle;
mlStyle.Scale = 20;
You can also find your answers @ TheSwamp
9 Kudos
Post 3 of 11
03-23-2011 05:01 PM in reply to: BrentBurgess1980
Yeah I am trying to create a multileader style and set the scale to 50. I might try creating it and the getting it from the DB and changing the scale.
9 Kudos
Post 4 of 11
03-23-2011 05:47 PM in reply to: Jeffrey_H
That didnt seem to work either. Do you know if there is any documentation on MLeaders?
Valued Mentor
13 Kudos
Post 5 of 11
03-23-2011 07:14 PM in reply to: BrentBurgess1980
Instead of setting the properties I copied from standard stlye and change the scale factor
Creates a new style named "newStyle"
  <CommandMethod("CreateMleaderStyle")> _
        Public Sub CreateMleaderStyle()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim mldrStyleDictionary As DBDictionary = db.MLeaderStyleDictionaryId.GetObject(OpenMode.ForWrite)
                Dim copyMleaderstyle As MLeaderStyle = mldrStyleDictionary.GetAt("Standard").GetObject(OpenMode.ForWrite)
                Dim newMleaderstyle As New MLeaderStyle()
                mldrStyleDictionary.SetAt("newStyle", newMleaderstyle)
                newMleaderstyle.CopyFrom(copyMleaderstyle)
                newMleaderstyle.Scale = 50
                trx.AddNewlyCreatedDBObject(newMleaderstyle, True)
                trx.Commit()
            End Using
        End Sub
9 Kudos
Post 6 of 11
03-23-2011 08:33 PM in reply to: Jeffrey_H
I have tried the code, and an interesting thig happens. In the MultiLeaderStyle dialog box, the scale is showing 50 - just what I want, but when I draw the MLeader and select it, the overall scale is 1.
Valued Mentor
13 Kudos
Post 7 of 11
03-23-2011 09:12 PM in reply to: BrentBurgess1980
9 Kudos
Post 8 of 11
03-24-2011 12:14 AM in reply to: BrentBurgess1980
Thats excellent!! now it is showing the scale I want.
New Member
0 Kudos
Post 9 of 11
03-31-2012 09:05 PM in reply to: BrentBurgess1980
Dear Sir,
I have the same issue. Could you please show me how to do it in C#? Thanks!
911 Kudos
Post 10 of 11
04-02-2012 07:35 PM in reply to: runCAD
runCAD wrote:
Dear Sir,
The link in the post 2 above yours which takes you to the Swamp has the C# solution.
