.NET
MultiLeader Arrow, set as none?
1 REPLY 1
C_Witt
368 Views, 1 Reply
How do I set a multileader arrow block to "none"?
I've tried via style and per object..  nothing seems to work..
If I manually set the style to "none" the ObjectID is listed as 0, but i can't set it to that in code..?
Can anyone give me a solution?
1 REPLY 1
C_Witt
in reply to: C_Witt
I've decided to cheat a little.
I saved a blank drawing with the "_None" block already in it, and have that block loaded from there when it's needed and then set that to the multileader.
If anyone has a more elegant (direct) solution I'd love to use it 🙂
”Boost
