.NET
mText
2 REPLIES 2
quigs
712 Views, 2 Replies
mText
Hi there,
I am adding some mtext to a jigs worlddraw. Using:
Dim Tx As New MText
Tx.Location = “a 3d point”
Tx.Contents = “a var that I have created”
draw.geometry.draw(tx)
The mtext displays fine, but I have tried in vain to change the font, to another but I am having no luck. Can anyone suggest a way that I may do that. Any font would do, so I can test it works.
Martin.
My name is Martin.. 😄
2 REPLIES 2
quigs
in reply to: quigs
I have found the solution:
      ' Get Font
            Dim acTextStyleTblRec As TextStyleTableRecord
            acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, OpenMode.ForWrite)
            acTextStyleTblRec.FileName = "Arial"
            acTrans.Commit()
            ' Mtext
            Dim IP As Point3d = InsPt
            Dim MText As New MText
            MText.Attachment = AttachmentPoint.BottomCenter
            MText.Contents = "21"
            MText.TextHeight = 6.4
            MText.Location = InsPt
            MText.ColorIndex = 7
            MText.TextStyle = acCurDb.Textstyle
            draw.Geometry.Draw(MText)
Hallex
in reply to: quigs
Martin,
Thanks for sharing the solution
Oleg
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
