.NET
mtext.TextStyleId in Arial format
3 REPLIES 3
joantopo
822 Views, 3 Replies
Hi.
I would like to do this for mtext:
try
   MText mt = new MText();
mt.TextStyleName="ARIAL";
catch{}
 But "TextStyleName" is only for read.
I can use "TextStyleId", so...How can I get the ObjectIdCollection of TextStyle and check which of them is "ARIAL"?
Thanks.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
joantopo
in reply to: joantopo
This is to create a new textstyle and make it current:
http://adndevblog.typepad.com/autocad/2012/06/creating-a-text-style-using-vbnet.html
But I want to check if there is a textstyle called "ARIAL" and create mtext with this textsytle.
SENL1362
       [CommandMethod("TestTextStyle")]
        static public void TestTextStyle()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string textStyleName = "Standard";
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    ed.WriteMessage("\n Default Textsize=={0}", db.Textsize);
                    TextStyleTable textStyleTable = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead);
                    if (!textStyleTable.Has(textStyleName))
                        throw new System.Exception(string.Format("Error: TextStyle not found: {0}", textStyleName));
                    ObjectId textStyleId = textStyleTable[textStyleName];
                    TextStyleTableRecord textStyle = (TextStyleTableRecord)tr.GetObject(textStyleId, OpenMode.ForRead);
                    ed.WriteMessage("\n {0} Size=={1}", textStyleName, textStyle.TextSize);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message);
joantopo
in reply to: SENL1362
Thanks a lot!
It´s just that.
              TextStyleTable TextStyleTable = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead);
              try
                  ObjectId textStyleId = TextStyleTable["ARIAL"];
                  mt.TextStyleId = textStyleId;
              catch { }
              mt.Contents = Contenido;
              mt.Layer = NombreCapa;
”Boost
