.NET
MText Associativity Exception
10 REPLIES 10
Message 1 of 11
kpschramm
1098 Views, 10 Replies
I am new to developing with this API but not to VB.NET.  I am trying to associate mtext to a leader using the instructions in the AutoCAD .NET Developer's Guide (115) for AutoCAD 2012 but keep getting the eInvalidInput exception.  One suggestion is that an exception is thrown if the mtext does not exist but I checked the mtext objectid for null and valid which returns good.  I am certain that I am missing something but not sure what.  I have included my source; the exception occurs at: acLdr.EvaluateLeader()
Thanks in Advance -Ken
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
Dim acBlkTblRec As BlockTableRecord
acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
'Create the MText annotation
Dim acMText As MText = New MText()
acMText.SetDatabaseDefaults()
acMText.Layer ="TEXT"
acMText.Contents = contents
'pt is a function that returns a Point3d(x, y, z) where z = 0
acMText.Location = pt(endPt.X + 2, endPt.Y + acMText.ActualHeight / 2)
acMText.Width = 70
'Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acMText)
acTrans.AddNewlyCreatedDBObject(acMText, True)
'Create the leader
Dim acLdr As Leader = New Leader()
acLdr.SetDatabaseDefaults()
acLdr.Layer = "DIM"
acLdr.AppendVertex(startPt)
acLdr.AppendVertex(breakPt)
acLdr.AppendVertex(endPt)
acLdr.HasArrowHead = True
acBlkTblRec.AppendEntity(acLdr)
acTrans.AddNewlyCreatedDBObject(acLdr,True)
'Attach the annotation after the leader object is added
acLdr.Annotation = acMText.Object
acTrans.Commit()
10 REPLIES 10
Message 2 of 11
Hallex
in reply to: kpschramm
Ken
I can't test it on a2012 but can you try as-is the next
slightly edited code
and also just a guess, check in leader settings number
of allowed verices manually
Type Leader in the command line then type S to see the things
Here is your code:
        <CommandMethod("DrawAnnoLeader", "dal", CommandFlags.Modal + CommandFlags.Redraw)> _
        Public Sub TestLeader()
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                acMText.Layer = "TEXT"
                acMText.Contents = "contents"
                acMText.Location = New Point3d(15, 15, 0)
                'acMText.Location = pt(endPt.X + 2, endPt.Y + acMText.ActualHeight / 2)
                acMText.Width = 70
                'Create the leader
                acLdr.Layer = "DIM"
                'acLdr.AppendVertex(startPt)
                'acLdr.AppendVertex(breakPt)
                'acLdr.AppendVertex(endPt)
                acLdr.AppendVertex(New Point3d(0, 0, 0))
                acLdr.AppendVertex(New Point3d(14, 14, 0))
                ' ldr.AppendVertex(New Point3d(4, 5, 0))
                acTrans.AddNewlyCreatedDBObject(acLdr, True)
                acLdr.Annotation = acMText.ObjectId
                acTrans.Commit()
            End Using
        End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
Why don't you use MLeader instead? Seems to be far easier to me at least
Message 4 of 11
kpschramm
in reply to: Hallex
Thank you Hallex but I am still getting the same exception, eInputInvalid.  Not that I am ready to give up on this but what about the MLeader suggestion?  I did a quick search in the Developer's Guide and didn't see any reference for it. The good news is the leader and mtext are working, I just can't associate them so it's not the end of the world but there is always an explanation to these type of issues.  Your feedback is appreciated.
Ken
Message 5 of 11
Hallex
Ken here is a sample to create mleader,
see if this is working on your end
    <CommandMethod("MLDF")> _
    Public Sub MleaderTest()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
        Dim dimld As Object = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dimldrblk")
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Try
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimldrblk", ".")
                Dim arrowPoint As Point3d = ed.GetPoint(vbLf & "Pick a point for the arrowhead: ").Value
                Dim pto As New PromptPointOptions(vbLf & "Pick a point for text: ")
                pto.UseBasePoint = True
                pto.UseDashedLine = True
                pto.BasePoint = arrowPoint
                Dim symbolPoint As Point3d = ed.GetPoint(pto).Value
                Dim vec As Vector3d
                If arrowPoint.X <= symbolPoint.X Then
                    vec = New Vector3d(1, 0, 0)
                Else
                    vec = New Vector3d(-1, 0, 0)
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim th As Double = db.Dimtxt
                Dim mtxt As New MText()
                mtxt.SetDatabaseDefaults()
                mtxt.Attachment = If(vec = New Vector3d(1, 0, 0), AttachmentPoint.MiddleLeft, AttachmentPoint.MiddleRight)
                mtxt.TextHeight = th
                mtxt.Width = 0.0
                mtxt.Contents = "Line 1\PLine 2\PLine 3"
                Dim mldr As New MLeader()
                mldr.LeaderLineType = LeaderType.StraightLeader
                ' --- add other properties here ---
                mldr.AddLeaderLine(arrowPoint)
                mldr.AddFirstVertex(0, arrowPoint)
                mldr.AddFirstVertex(1, symbolPoint)
                mldr.ArrowSymbolId = db.Dimldrblk
                Dim dict As DBDictionary = DirectCast(tr.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead), DBDictionary)
                Dim mlstyleid As ObjectId = dict.GetAt("Standard")
                mldr.MLeaderStyle = mlstyleid
                mldr.ContentType = ContentType.MTextContent
                mldr.MText = mtxt
                mldr.TextLocation = symbolPoint
                mldr.SetDogleg(0, vec)
                mldr.LandingGap = th / 4
                mldr.DoglegLength = th
                btr.AppendEntity(mldr)
                tr.AddNewlyCreatedDBObject(mldr, True)
                tr.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
            Finally
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimldrblk", dimld)
            End Try
        End Using
    End Sub
~'J'~
Message 6 of 11
kpschramm
in reply to: Hallex
Hallex ... Your test MLeader worked!  Thanks to TobyRsenberg8728 for the suggestion!  Is there any reason why I shouldn't mark this as a workable solution?  Also, should this be reported as a bug on AutoCAD 2012 considering the example code in the Developer's Guide does not work as written?
Thank you!
Message 7 of 11
Hallex
Ken,
Don't hurry up, I'm still working on this issue, just a guess, maybe
you need to look at any ...ASSOC system variables
Keep watching for,
Regardfs,
Oleg
~'J'~
Message 8 of 11
Hallex
in reply to: Hallex
In addition
I can not reconstruct the same issue here
what from my investigating is DIMASSOC variable
does not effect at all, the leader mtext stll associative
undependently
So sorry I don't know how to solve this problem
~'J'~
Message 9 of 11
kpschramm
in reply to: Hallex
Hallex,
That's quite alright.  I have 2 options now, MLeader or  non-associated MText + Leader, so I will be able to proceed.  Although the MLeader is an option and not a fix to the underlying issue, do you think I should mark this thread as answered?
Ken
Message 10 of 11
Hallex
Happy to help, Ken
Happy computing,
Cheers 🙂
Oleg
Message 11 of 11
Hugh_Compton
Hello
The code example above works well but I use Annotative Text.  This means the line
Dim th AsDouble = db.Dimtxt
returns a text ht that doesn't factor in the Annotative scale.  Is there a work around for this?
”Boost
