.NET
MsgBox error..?
11 REPLIES 11
Message 1 of 12
490 Views, 11 Replies
MsgBox error..?
It doesn't seem to matter how I use this tool I keep getting errors..
like this..
Request for the permission of type
'System.Security.Permissions.SecurityPermission, mscorlib,
Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
failed.
Anyone know what I need to do to fix this?..    (I got that error from
this code..   MsgBox("Hi")   )
Work: VISTA Ultimate x32 - AMD 64 X2
Dual Core 4200 2.2GHz, 4 Gigs Ram, GeForce
6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad
Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 -
color="#000000">AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram,
color="#666666">Nvidia GeForce 6150
11 REPLIES 11
Message 2 of 12
Spend some time learning the .NET framework, rather than
treating VB.NET as an incremental upgrade to legacy VB.
See the MessageBox.Show() method in the docs.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"C Witt" wrote in message news:5985624@discussion.autodesk.com...
It doesn't seem to matter how I use this tool I keep getting errors.. like this..
Request for the permission of type 'System.Security.Permissions.SecurityPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
Anyone know what I need to do to fix this?.. (I got that error from this code.. MsgBox("Hi") )
Work: VISTA Ultimate x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs Ram, GeForce 6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 - AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram, Nvidia GeForce 6150
Message 3 of 12
ok,
I only used that method as that is what is used in the labs (that you
seem to think i should be following).
Message 4 of 12
seem to think i should be following). <<
Yes, the labs are what you should follow, *after* you've learned the basics of using the .NET framework and the programming language you're using.
The labs are primarily for learning the ObjectARX API, not the .NET framework or any .NET language.
I'm not sure if its written anywhere, but the labs and most of Autodesk's learning/training materials presume that you already have a reasonable level of knowledge/experience with the .NET framework and the .NET language you're using.
Your problem (in this case) has nothing to do with the AutoCAD .NET API, you just haven't taken the time to learn about the .NET framework (something that does not exist in legacy VB). So, essentially, you're trying to run before you've learned to walk.
"C Witt" wrote in message news:5985846@discussion.autodesk.com...
ok,
Message 5 of 12
Please show more of your code.
Joe ...
ok,
Message 6 of 12
There really isn't "any other code"..  even when i strip it down to
just the box, it still happens..
public sub test()
    msgbox("hi")
end sub
Imports System.Windows.Forms
public sub test()
    messagebox.show("hi")
end sub
Both result in security errors..     Now I don't remember having this
problem at the start of the year.. so I'm thinking it could be a recent
windows security patch for vista?  (I'm using .Net Express 2005)
Work: VISTA
color="#666666">GeForce 6800GS 256MB
Joe ...
"C Witt" <cwitt_AT_trkeng.com> wrote in message
ok,
Message 7 of 12
Just switched to 2008 express..  same errors..
Work: VISTA
public sub test()
    msgbox("hi")
end sub
public sub test()
end sub
Work: VISTA
Quad
Joe ...
href="news:5985846@discussion.autodesk.com">news:5985846@discussion.autodesk.com
ok,
Message 8 of 12
Copy and paste into a reply, the the entire contents of the detail shown in the error dialog.
Also, is this a standard Windows .exe or dll loaded into AutoCAD?
Lastly, how did you create the project?
"C Witt" wrote in message news:5986559@discussion.autodesk.com...
C Witt wrote:
There really isn't "any other code".. even when i strip it down to just the box, it still happens..
public sub test()
msgbox("hi")
end sub
public sub test()
end sub
Both result in security errors.. Now I don't remember having this problem at the start of the year.. so I'm thinking it could be a recent windows security patch for vista? (I'm using .Net Express 2005)
Joe ...
ok,
Message 9 of 12
The 2 commands..
<CommandMethod("Box1")> _
Public Sub testbox1()
    MsgBox("hi")
End Sub
<CommandMethod("Box2")> _
Public Sub testbox2()
    MessageBox.Show("hi")
End Sub
Attached are the txt files with the errors
It is a dll loaded into AutoCAD (2009)
The original project was created in 2005 Express from the "AutoCAD
VB.NET Application" template (installed with a program from
www.vbcad.com).
Work: VISTA
Message 10 of 12
Is your project and DLL on the local system, or on a network drive (mapped to a local drive letter) ?
"C Witt" wrote in message news:5986674@discussion.autodesk.com...
The 2 commands..
_
   MsgBox("hi")
End Sub
_
End Sub
The original project was created in 2005 Express from the "AutoCAD VB.NET Applicatio n" template (installed with a program from www.vbcad.com).
Home: VISTA Ultimate x64 - AMD 64 Quad Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB< /font>
oaded into AutoCAD?
Message 11 of 12
Well this is annoying..   I had a thought..  I moved all the files onto
a networked drive at the start of the year..     I just moved them to
my local drive, ran the programs and it works great.
Good to know, but sucks for potability (I work on this at work &
home).
Back to the grind.   Thanks Tony/Joe.
Work: VISTA
C Witt wrote:
The 2 commands..
    MsgBox("hi")
End Sub
End Sub
VB.NET Applicatio
href="http://www.vbcad.com">www.vbcad.com
Work: VISTA
Quad
/font>
color="#000000">
oaded into AutoCAD?
Message 12 of 12
The security model .NET uses requires that assemblies located on the intranet (as opposed to the local system), must be explicitly 'trusted', which can be done using the .NET configuration tools.
"C Witt" wrote in message news:5986706@discussion.autodesk.com...
Well this is annoying..  I had a thought.. I moved all the files onto a networked drive at the start of the year..    I just moved them to my local drive, ran the programs and it works great.
Good to know, but sucks for potability (I work on this at work & home).
C Witt wrote:
The 2 commands..
_
   MsgBox("hi")
End Sub
_
End Sub
oaded into AutoCAD?
”Boost
