.NET
Moving text within an AutoCAD drawing
3 REPLIES 3
hassanhafeez33
1075 Views, 3 Replies
I am, as of now, trying to learn the VB.NET programming for AutoCAD applications from scratch and I have done a few tutorials and labs from DevTV and googling 🙂
The question I wanted to ask the devs out there is that, is there any way or a funtion to move a text object within a layer to a different geometric location? I was thinking it could be accomplished by translating the text or offsetting it. If someone could guide me in the right direction, it would be great help.
And sorry if I mistakingly did not observe forum rules or something 🙂
Thanks in advance!
3 REPLIES 3
arcticad
in reply to: hassanhafeez33
You can move the Text by Changing it's position properties
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Public Class Class2
    <CommandMethod("MoveText")> _
    Public Sub MoveText()
        Using db As Database = HostApplicationServices.WorkingDatabase()
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Using lock As DocumentLock = myDWG.LockDocument
                    Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices. _
                    Application.DocumentManager.MdiActiveDocument.Editor()
                    Dim sOptions As New PromptEntityOptions(vbCr & "Select Text: ")
                    Dim sRes As PromptEntityResult = Nothing
                    While (True)
                        ' Select Text
                        sRes = ed.GetEntity(sOptions)
                        If sRes.Status <> PromptStatus.OK Then
                            Exit While
                        Else
                            Dim obj As Object = tr.GetObject(sRes.ObjectId, OpenMode.ForRead)
                            If TypeOf obj Is DBText Then
                                Dim objdbTEXT As DBText = tr.GetObject(obj.objectid, OpenMode.ForWrite)
                                ' Move Text to Position
                                Dim POINT3D As New Autodesk.AutoCAD.Geometry.Point3d(0, 0, 0)
                                objdbTEXT.Position = POINT3D
                                ' Update Changes
                                db.TransactionManager.QueueForGraphicsFlush()
                            End If
                        End If
                    End While
                End Using
                ' Save Changes
                tr.Commit()
            End Using
        End Using
    End Sub
End Class
(defun botsbuildbots() (botsbuildbots))
hassanhafeez33
in reply to: arcticad
Thanks Arcticad, Thats a bit much of a code for me. I havent had the chance to see this many fuctions yet.
Ive got a couple more of requests. Could you comment the code that you wrote as well?
and here is another bit of code I am trying to use but for some reason, the objects in the other two layers get green colour inspite of the inner transaction running on the condition of layer 0 selection.
<CommandMethod("SelectObjectsOnscreen")> _
        Public Sub SelectObjectsOnscreen()
            ' Get the current document and database
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            ' Start a transaction
            Using acTrans1 As Transaction = acCurDb.TransactionManager.StartTransaction()
                ' Open the Layer table for read
                Dim acLyrTbl As LayerTable
                acLyrTbl = acTrans1.GetObject(acCurDb.LayerTableId, _
                                                   OpenMode.ForRead)
                Dim sLayerName As String = "0"
                If acLyrTbl.Has(sLayerName) = True Then
                    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                        ' Request for objects to be selected in the drawing area
                        Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection()
                        ' If the prompt status is OK, objects were selected
                        If acSSPrompt.Status = PromptStatus.OK Then
                            Dim acSSet As SelectionSet = acSSPrompt.Value
                            ' Step through the objects in the selection set
                            For Each acSSObj As SelectedObject In acSSet
                                'Check to make sure a valid SelectedObject object was returned
                                If Not IsDBNull(acSSObj) Then
                                    ' Open the selected object for write
                                    Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, _
        OpenMode.ForWrite)
                                    If Not IsDBNull(acEnt) Then
                                        ' Change the object's color to Green
                                        acEnt.ColorIndex = 3
                                    End If
                                End If
                            Next
                            If sLayerName = "0" Then
                                ' Save the new object to the database
                                acTrans.Commit()
                            End If
                        End If
                    End Using
                    ' Dispose of the transaction
                End If
                acTrans1.Commit()
            End Using
        End Sub
ditran7577
Hello Pro,
How to select block and put them by group with layer or tag...on form.
”Boost
