.NET
MouseMove ?
5 REPLIES 5
319 Views, 5 Replies
MouseMove ?
I need a way to create a circle in AutoCAD 2007 and let the user move it around the screen to a desired position, then place it with a mouse click.
I can draw a circle, but I cant find a way to obtain the current position of the mouse in autoCAD to move the circle. Is there a way ?
I have seen a few posts on Drag / Drop but none of then seem to give a definite answer. Can anyone give a few hints on which way to go ?
j
5 REPLIES 5
Read this topic: http://www.theswamp.org/index.php?topic=11340.0
Have a look at the following sample shipped with ObjectARX:
samples\dotNet\EllipseJig
It uses the Drag method of the Editor which standardizes the process
Thanks Pavlos and Alexander for your answers.
Alex, following your thread I have ended on this link given by Tony Tanzillo.
http://www.caddzone.com/InsertJig.cs
If I try to translate the code to VB.NET I get an error on the line
JigPromptOptions jigOpts = new JigPromptOptions();
translated to :
Dim jigOpts As New JigPromptOptions()
On VB the error given is :
'New' cannot be used on a class that is declared 'MustInherit'
And if I put the code into a C# project it gives :
Cannot create an instance of the abstract class or interface
AutoDesk.AutoCAD.EditorInput.JigPromptOptions
Does anyone know why this happens ?
j.
What version of AutoCAD and MS VS you using?
This smple compiled witout errors in VS 2002, 2005< SharpDeveloper 2.0 Message was edited by: Alexander Rivilis
cgay
Here is the ellipse jig sample translated to VB.NET 2005
Hope it helps.
C
”Boost
