I have got a ribbon that loads using a dll
At the moment i have got it monitoring to see if the "WSCURRENT" changes but when the profile changes it doesnt change the "WSCURRENT"
as long as its not autocad calssic it will reload the ribbon
If Not Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("WSCURRENT").ToString.ToLower = "autocad classic" Then
How can i monitor for a profile change ?
Solved by makepeace1. Go to Solution.
You could look at Event Handlers. I am not sure what one but I would assume there is some kind of event that could be used for this.
ok
I have worked out how to do it but it seems to unload again once i click ok to close the window where you change the profile
AddHandler Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager.CurrentProfileChanged, AddressOf acApp_CurrentProfileChanged
Private Sub acApp_CurrentProfileChanged(ByVal sender As Object, ByVal e As ProfileEventArgs) LOADMENU() End Sub
Any idea's?
I asked the question to autodesk this is the reponse that i got
The RibbonPaletteSet.Loaded event is the best way to ensure your ribbon items get re-created whenever a disrupting action occurs in AutoCAD.
Here is a complete example:
[CommandMethod("SimpleButton")] public void SimpleButton() { RibbonServices.RibbonPaletteSet.Loaded += new EventHandler(RibbonPaletteSet_Loaded); // Makes sure Ribbon is visible (crash otherwise) // If not make Ribbon visible if (Autodesk.Windows.ComponentManager.Ribbon != null) { CreateSimpleButton(); } else { Autodesk.AutoCAD.ApplicationServices.Application.Idle += new EventHandler(Application_Idle); Document doc = Application.DocumentManager.MdiActiveDocument; doc.SendStringToExecute("RIBBON ", true, false, false); } } void RibbonPaletteSet_Loaded(object sender, EventArgs e) { Autodesk.AutoCAD.ApplicationServices.Application.Idle += new EventHandler(Application_Idle); } void Application_Idle(object sender, EventArgs e) { if (Autodesk.Windows.ComponentManager.Ribbon != null) { Autodesk.AutoCAD.ApplicationServices.Application.Idle -= new EventHandler(Application_Idle); var ribbon = Autodesk.Windows.ComponentManager.Ribbon; var tab = ribbon.FindTab("ADN_TAB_ID"); if (tab == null || !tab.IsVisible) { CreateSimpleButton(); } } } public void CreateSimpleButton() { RibbonControl ribbonControl = ComponentManager.Ribbon; RibbonTab Tab = new RibbonTab(); Tab.Title = "Test Ribbon"; Tab.Id = "ADN_TAB_ID"; ribbonControl.Tabs.Add(Tab); RibbonPanelSource srcPanel = new RibbonPanelSource(); srcPanel.Title = "Panel1"; RibbonPanel Panel = new RibbonPanel(); Panel.Source = srcPanel; Tab.Panels.Add(Panel); Autodesk.Windows.RibbonButton button1 = new RibbonButton(); button1.Text = "Button"; button1.Size = RibbonItemSize.Large; button1.Orientation = System.Windows.Controls.Orientation.Horizontal; button1.Image = getBitmap(Properties.Resources.Apps, 16, 16); button1.LargeImage = getBitmap(Properties.Resources.Apps, 32, 32); button1.ShowText = false; button1.CommandParameter = "._LINE "; button1.CommandHandler = new SimpleButtonCmdHandler(); srcPanel.Items.Add(button1); Tab.IsActive = true; } //Use: getBitmap(Properties.Resources.a_large); BitmapImage getBitmap(Bitmap bitmap, int height, int width) { MemoryStream stream = new MemoryStream(); bitmap.Save(stream, System.Drawing.Imaging.ImageFormat.Png); BitmapImage bmp = new BitmapImage(); bmp.BeginInit(); bmp.StreamSource = new MemoryStream(stream.ToArray()); bmp.DecodePixelHeight = height; bmp.DecodePixelWidth = width; bmp.EndInit(); return bmp; } public class SimpleButtonCmdHandler : System.Windows.Input.ICommand { public bool CanExecute(object parameter) { return true; } public event EventHandler CanExecuteChanged; public void Execute(object parameter) { if (parameter is RibbonButton) { // builds escape sequence to cancel active commands string esc = ""; string cmds = (string) Application. GetSystemVariable("CMDNAMES"); if (cmds.Length > 0) { int cmdNum = cmds.Split(new char[] { '\'' }).Length; for (int i = 0; i < cmdNum; i++) esc += '\x03'; } RibbonButton button = parameter as RibbonButton; Document doc = Application. DocumentManager.MdiActiveDocument; doc.SendStringToExecute(esc + button.CommandParameter, true, false, false); } } }
Seems to do the job
