.NET
Active Contributor
makepeace1
Message 1 of 4 (149 Views)
Monitor for profile change
149 Views, 3 Replies
05-16-2014 02:16 AM
I have got a ribbon that loads using a dll
At the moment i have got it monitoring to see if the "WSCURRENT" changes but when the profile changes it doesnt change the "WSCURRENT"
as long as its not autocad calssic it will reload the ribbon
 If Not Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("WSCURRENT").ToString.ToLower = "autocad classic" Then
How can i monitor for a profile change ?
I asked the question to autodesk this is the reponse that i got
The RibbonPaletteSet.Loaded event is the best way to ensure your ribbon items get re-created whenever a disrupting action occurs in AutoCAD.
Here is a complete example:
[CommandMethod("SimpleButton")]
public void SimpleButton()
RibbonServices.RibbonPaletteSet.Loaded +=
new EventHandler(RibbonPaletteSet_Loaded);
// Makes sure Ribbon is visible (crash otherwise)
// If not make Ribbon visible
if (Autodesk.Windows.ComponentManager.Ribbon != null)
CreateSimpleButton();
else
Autodesk.AutoCAD.ApplicationServices.Application.Idle +=
new EventHandler(Application_Idle);
Document doc = Application.DocumentManager.MdiActiveDocument;
doc.SendStringToExecute("RIBBON ", true, false, false);
void RibbonPaletteSet_Loaded(object sender, EventArgs e)
void Application_Idle(object sender, EventArgs e)
Autodesk.AutoCAD.ApplicationServices.Application.Idle -=
var ribbon = Autodesk.Windows.ComponentManager.Ribbon;
var tab = ribbon.FindTab("ADN_TAB_ID");
if (tab == null || !tab.IsVisible)
public void CreateSimpleButton()
RibbonControl ribbonControl =
RibbonTab Tab = new RibbonTab();
Tab.Title = "Test Ribbon";
Tab.Id = "ADN_TAB_ID";
ribbonControl.Tabs.Add(Tab);
RibbonPanelSource srcPanel =
new RibbonPanelSource();
srcPanel.Title = "Panel1";
RibbonPanel Panel = new RibbonPanel();
Panel.Source = srcPanel;
Tab.Panels.Add(Panel);
Autodesk.Windows.RibbonButton button1 =
new RibbonButton();
button1.Text = "Button";
button1.Size = RibbonItemSize.Large;
button1.Orientation = System.Windows.Controls.Orientation.Horizontal;
button1.Image =
getBitmap(Properties.Resources.Apps, 16, 16);
button1.LargeImage =
getBitmap(Properties.Resources.Apps, 32, 32);
button1.ShowText = false;
button1.CommandParameter = "._LINE ";
button1.CommandHandler = new SimpleButtonCmdHandler();
srcPanel.Items.Add(button1);
Tab.IsActive = true;
//Use: getBitmap(Properties.Resources.a_large);
BitmapImage getBitmap(Bitmap bitmap, int height, int width)
MemoryStream stream = new MemoryStream();
bitmap.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
BitmapImage bmp = new BitmapImage();
bmp.BeginInit();
bmp.StreamSource = new MemoryStream(stream.ToArray());
bmp.DecodePixelHeight = height;
bmp.DecodePixelWidth = width;
bmp.EndInit();
return bmp;
public class SimpleButtonCmdHandler :
System.Windows.Input.ICommand
public bool CanExecute(object parameter)
return true;
public event EventHandler CanExecuteChanged;
public void Execute(object parameter)
if (parameter is RibbonButton)
// builds escape sequence to cancel active commands
string esc = "";
string cmds = (string) Application.
GetSystemVariable("CMDNAMES");
if (cmds.Length > 0)
int cmdNum = cmds.Split(new char[] { '\'' }).Length;
for (int i = 0; i < cmdNum; i++)
esc += '\x03';
RibbonButton button = parameter as RibbonButton;
doc.SendStringToExecute(esc + button.CommandParameter,
 Seems to do the job
Distinguished Contributor
quigs
Message 2 of 4 (117 Views)
Re: Monitor for profile change
05-18-2014 03:25 AM in reply to: makepeace1
You could look at Event Handlers.  I am not sure what one but I would assume there is some kind of event that could be used for this.
My name is Martin.. :smileyvery-happy:
Active Contributor
makepeace1
Message 3 of 4 (100 Views)
05-19-2014 02:46 AM in reply to: quigs
ok
I have worked out how to do it but it seems to unload again once i click ok to close the window where you change the profile
AddHandler Autodesk.AutoCAD.ApplicationServices.Application.UserConfigurationManager.CurrentProfileChanged, AddressOf acApp_CurrentProfileChanged
Private Sub acApp_CurrentProfileChanged(ByVal sender As Object, ByVal e As ProfileEventArgs)
            LOADMENU()
        End Sub
 Any idea's?
Active Contributor
makepeace1
Message 4 of 4 (88 Views)
05-20-2014 01:48 AM in reply to: makepeace1
    else
        new RibbonButton();
    button1.Image =
    bmp.BeginInit();
    bmp.EndInit();
    return bmp;
        return true;
            string esc = "";
                    esc += '\x03';
 Seems to do the job
