.NET
Modifying Source Entities in Arrays
1 REPLY 1
BellwetherBill
449 Views, 1 Reply
I am trying to write some code in .net to modify a dimensional constraint that is attached to a source entity of an array that is nested in a block. Specifically I have a line and a dim constraint that control the length of the line. I have tried a couple of methds so far. I can change the dim constraint if I loop through the top level AssocNetwork and SubNetworks looking for the AssocVariable of the constraint then modifying the constraint updates the length of the line. The problem with this approach is that all the BlockReferences get updated to the new line length.
Alternatively, I can access the AssocArray by selecting the block reference. With this method I cannot seem to figure out how to get the AssocVariable from the source entities. Can anyone help with this?
I'm attaching a drawiing and some test code. I'm using Autocad and VS2012.
<CommandMethod("TestEnt")> _
    Public Sub TestEnt()
        Dim entId As ObjectId
        Dim Success As Boolean
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Success = GetTestEntity(entId)
        If Success Then
            Using trans As Transaction = db.TransactionManager.StartTransaction()
                Dim br As BlockReference = DirectCast(trans.GetObject(entId, OpenMode.ForWrite, False), BlockReference)
                Dim btr As BlockTableRecord = DirectCast(trans.GetObject(br.BlockTableRecord, OpenMode.ForWrite, False), BlockTableRecord)
                For Each NestEntID As ObjectId In btr
                    Dim ent As Entity = trans.GetObject(NestEntID, OpenMode.ForWrite, False)
                    If AssocArray.IsAssociativeArray(NestEntID) Then
                        Dim Ar As AssocArray = AssocArray.GetAssociativeArray(NestEntID)
                        For Each actionId As ObjectId In Ar.SourceEntities
                            'doc.Editor.WriteMessage(vbCrLf & "ActionObjId: " & actionId.ToString)
                            If actionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Dimension))) Then
                                Dim DepIds As ObjectIdCollection = AssocDependency.GetDependenciesOnObject(ent, True, True)
                                For Each did In DepIds
                                    Dim Dep As AssocDependency = trans.GetObject(did, OpenMode.ForWrite, False)
                                    Dim AnotherActionId As ObjectId = Dep.DependencyBody
                                    If AnotherActionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.AssocDimDependencyBody))) Then
                                        Dim var As AssocVariable = DirectCast(trans.GetObject(AnotherActionId, OpenMode.ForWrite), AssocVariable)
                                        MsgBox("Variable")
                                Next
                        Next
                Next
            End Using
    End Sub
 Private Function GetTestEntity(ByRef obj As ObjectId) As Boolean
        'get the current active document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDB As Database = acDoc.Database
        'set the prompt options for the get entity function
        Dim prEntOpt As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select an entity: ")
        'dont't allow selecting nothing
        prEntOpt.AllowNone = False
        'set the reject message if not selecting the proper entity
        prEntOpt.SetRejectMessage(vbLf & "Must select an entity Douche..... ")
        'make it so we can only select a
        'prEntOpt.AddAllowedClass(GetType(Entity), True)
        'go selct the entity
        Dim prEntRes As PromptEntityResult
        prEntRes = acDoc.Editor.GetEntity(prEntOpt)
        'make sure the user doesn't cancel and
        'return the object id for querying
        If prEntRes.Status = PromptStatus.OK Then
            obj = prEntRes.ObjectId
            Return True
        Else
            Debug.WriteLine(prEntRes.Status)
            Return False
    End Function
1 REPLY 1
If anyone is interested...Here is some code that works with the TestArray.dwg. I don't know if this is the best approach, but it seems to work.
        Dim errmsg As String = ""
        Dim UnitWidth As String
        'select the block
        If Success Then
                If br.IsDynamicBlock Then
                    Dim dynBRPropCol As DynamicBlockReferencePropertyCollection = br.DynamicBlockReferencePropertyCollection
                    For Each itm As DynamicBlockReferenceProperty In dynBRPropCol
                        ' doc.Editor.WriteMessage(vbLf & "Proper Name: " & itm.PropertyName & vbLf & _
                        '                        "Property Value: " & itm.Value.ToString)
                        Select Case itm.PropertyName
                            Case "Width"
                                UnitWidth = itm.Value.ToString
                        End Select
                    Next
                            Dim actionId As ObjectId = Ar.SourceEntities(0)
                            If actionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Entity))) Then
                                Dim RL As Entity = DirectCast(trans.GetObject(actionId, OpenMode.ForWrite), Entity)
                                'Dim RLbtr As BlockTableRecord = DirectCast(trans.GetObject(RL.BlockId, OpenMode.ForWrite, False), BlockTableRecord)
                                'Open the AssocNetwork
                                Dim networkId As ObjectId = AssocNetwork.GetInstanceFromObject(RL.BlockId, False, False, "")
                                Dim network As AssocNetwork = DirectCast(trans.GetObject(networkId, OpenMode.ForWrite), AssocNetwork)
                                For Each AnotheractionId As ObjectId In network.GetActions
                                    If AnotheractionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.AssocVariable))) Then
                                        ''Is this action an AssocVariable?*********
                                        Dim var As AssocVariable = DirectCast(trans.GetObject(AnotheractionId, OpenMode.ForWrite), AssocVariable)
                                        If Not var Is Nothing Then
                                            Select Case var.Name
                                                Case "RafterLength"
                                                    var.SetExpression(UnitWidth, "", True, True, errmsg, True)
                                            End Select
                                            'MsgBox(var.Name)
                                Next
                    Next
                    trans.Commit()
            End Using
    End Sub
”Boost
