.NET
Modifying Code During Debug
4 REPLIES 4
261 Views, 4 Replies
When developing VB6 DLL's it was possible to reference the started DLL and
then edit code after a break point was reached. The way I've started to
develop .Net DLL's is to use Debug -> Start with AutoCAD specified as the
external program to start when debugging.
The problem is that I can't seem to edit the code after a Break point is
reached. Is there any way to accomplish this?? I's definitely a hindrance.
Dale
4 REPLIES 4
Dale,
From the menu Tools | Options | Debugging | Edit and Continue ... check the
option "allow me to edit VB files while debugging"
It'll let you type in code after a break. But you won't be able to run the
new code (like in VB 6) until you re-compile. I've read that break, edit &
continue will come back in VS.net 2005. I can't wait!
Marty
"Dale Levesque" wrote in message
news:4950751@discussion.autodesk.com...
Dale
cgay
Dale,
You are using VS.NET 2002 or 2003 I presume. The feature you are talking about was/is called "Edit and Continue". Unfortunately, M$ decided to take it out of VB.NET 2002/03. I believe it will be coming back, in VS 2005, due to an overwhelming negative response from the VB community.
In 2003 you can turn "Edit and Continue" on in the Tools->Options->Debugging->Edit and Continue->"Allow me to edit VB files while debugging", unfortunately, this is not the same "Edit and Continue" of old. It will allow you to edit the file, then it will prompt you to "Edit and Continue" or "Edit and Restart". "Edit and Continue" basically continues execution as if you hadn't made any changes until you restart the debugging session. "Edit and Restart" stops execution and restarts the debugging session from the beginning.
CG
Thanks. Pretty lame. That is going to be annoying. I hope the upgrade comes
out soon. I'll try the beta to make sure it works.
Dale
wrote in message news:4950987@discussion.autodesk.com...
Dale,
CG
Visual Studio 2005 is scheduled to ship on November 7.
Dan
news:4950981@discussion.autodesk.com...
Dale
Dale,
CG
”Boost
