.NET
Modify block definition
7 REPLIES 7
Message 1 of 8
alex_b
1291 Views, 7 Replies
Hi.
I'm trying to modify Block definitions in dwg files from an out-of-process app.
    It has to work for ACAD 2004.
I can add entities to the block definition but only when I know the entity type in advance (e.g. block.AddLine() etc.).
What I mean is I need to copy entities from a source (e.g. another drawing) and add them to the block definition, without checking the entity type.
I notice there is no generic AcadBlock.Add() or AddObject() or AddEntity().
Would it be possible to do it at all?
alex
7 REPLIES 7
Message 2 of 8
hgasty1001
in reply to: alex_b
Firts the bad news: 2004 does not support .NET API, you need 2005 at least, but that was almost experimental, so it's better to get a more modern version of AutoCAD. As for the block definition, you can check this: http://through-the-interface.typepad.com/through_the_interface/2010/01/creating-an-autocad-block-usi...
Gaston Nunez
Message 3 of 8
alex_b
in reply to: hgasty1001
Spoiler
Hi Gaston
I am using COM ActiveX quite successfully for 2004.
I saw Kean's article at his blog, it's not quite what I need.
I'm looking for a solution to the specific problem I mentioned.
Maybe the Autodesk people will see this and come forward.
You said 'first the bad news'.
OK. Where are the good news? Smiley Happy
Message 4 of 8
hgasty1001
in reply to: alex_b
Well, this is the .NET forum, may be you can find more help in the VB/VBA forum.
Gaston Nunez
Message 5 of 8
Hallex
in reply to: alex_b
Not sure about if this helps,
try the quick code example,
just change file names and block name
to your suit
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 6 of 8
alex_b
in reply to: Hallex
Hallex
Awesome, Thank you. This is just what I'm looking for.
I wasn't aware of AcadDocument.CopyObjects().
All I have to do now is translet your VB code to C#.
Thx again
alex
Message 7 of 8
Hallex
in reply to: alex_b
You're welcome,
Glad to help
Cheers Smiley Happy
~'J'~
Message 8 of 8
alex_b
in reply to: Hallex
In case it will be useful to anyone, here is a method, based on Hallex's code translated to C# Interop,
which performs a INSERT =.
Cheers
alex
”Boost
