.NET
Distinguished Contributor
alex_b
Message 1 of 8 (492 Views)
Modify block definition
492 Views, 7 Replies
09-24-2012 06:06 AM
Hi.
I'm trying to modify Block definitions in dwg files from an out-of-process app.
    It has to work for ACAD 2004.
I can add entities to the block definition but only when I know the entity type in advance (e.g. block.AddLine() etc.).
What I mean is I need to copy entities from a source (e.g. another drawing) and add them to the block definition, without checking the entity type.
I notice there is no generic AcadBlock.Add() or AddObject() or AddEntity().
Would it be possible to do it at all?
alex
Not sure about if this helps,
try the quick code example,
just change file names and block name
to your suit
~'J'~
Distinguished Mentor
gasty1001
Message 2 of 8 (482 Views)
Re: Modify block definition
09-24-2012 07:32 AM in reply to: alex_b
Firts the bad news: 2004 does not support .NET API, you need 2005 at least, but that was almost experimental, so it's better to get a more modern version of AutoCAD. As for the block definition, you can check this: http://through-the-interface.typepad.com/through_the_interface/2010/01/creating-an-autocad-block-usi...
Gaston Nunez
alex_b
Message 3 of 8 (471 Views)
09-24-2012 08:20 AM in reply to: gasty1001
Spoiler
Hi Gaston
I am using COM ActiveX quite successfully for 2004.
I saw Kean's article at his blog, it's not quite what I need.
I'm looking for a solution to the specific problem I mentioned.
Maybe the Autodesk people will see this and come forward.
You said 'first the bad news'.
OK. Where are the good news? :smileyhappy:
gasty1001
Message 4 of 8 (468 Views)
09-24-2012 08:31 AM in reply to: alex_b
Well, this is the .NET forum, may be you can find more help in the VB/VBA forum.
Gaston Nunez
Hallex
Message 5 of 8 (428 Views)
09-25-2012 08:58 AM in reply to: alex_b
to your suit
~'J'~
alex_b
Message 6 of 8 (418 Views)
09-25-2012 11:06 AM in reply to: Hallex
Hallex
Awesome, Thank you. This is just what I'm looking for.
I wasn't aware of AcadDocument.CopyObjects().
All I have to do now is translet your VB code to C#.
Thx again
alex
Hallex
Message 7 of 8 (409 Views)
09-25-2012 12:58 PM in reply to: alex_b
You're welcome,
Glad to help
Cheers :smileyhappy:
~'J'~
alex_b
Message 8 of 8 (389 Views)
09-26-2012 04:05 AM in reply to: Hallex
In case it will be useful to anyone, here is a method, based on Hallex's code translated to C# Interop,
which performs a INSERT =.
Cheers
alex
