.NET
Modification of the DGNpurge tool
3 REPLIES 3
fsztuczny
923 Views, 3 Replies
I tried to modify the tool posted on there in such a way that it is possible to batch processing of files. As input are the Database and the Editor (null if batch processing mode). If it has been used in the current document, there is no problem. If the function argument gave an external Database, there is an exception to the "eNtoFromThisDocument" function:
private static ObjectIdCollection
PurgeLinetypesReferencedNotByAnonBlocks (
Database db, Transaction tr, ObjectIdCollection ids
line 283 in the fragment:
//Open the object and check its lineType.2point=2 point
var obj = tr.GetObject (id, OpenMode. ForRead, true);
Here pasted code.
Please help.
3 REPLIES 3
This error means that the ID you are trying to open don't belong to the database...
If you have an ObjectID, you can get the owner Database from ObjectId.Database property, then get the transaction from there...
But on your new version of the code, you may consider review to make sure this logic is as expected.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
fsztuczny
in reply to: fsztuczny
Help please. This tool is going to crash in the attached drawing (link).
https://www.dropbox.com/s/ku9bagkaak6v0sg/4228-1000-15-DW-500_RA_1.dwg
”Boost
