.NET
Distinguished Contributor
junoj
Message 1 of 12 (467 Views)
Accepted Solution
ModelSpace vs. PaperSpace Viewport
467 Views, 11 Replies
08-18-2013 10:32 PM
Hi, is there a way to be able to distinguish if the ModelSpace from PaperSpace Viewport. ‘.CurrentSpaceId’ points to the model space when looking at the model space via paperspace viewport.
You can use the Database.TileMode property to know if the current layout is the Model Layout or any other layout
You can use the Database.CurrentSpaceId to get the current space and compare it to theobjectId return by SymbolUtilityServices.GetBlockModelSpaceId()
 if (db.TileMode)
// The Model layout is active
else if (db.CurrentSpaceId == SymbolUtilityServices.GetBlockModelSpaceId(db))
// A floating viewport in a paper space layout is active
else
// A paper space is active
*Expert Elite*
_gile
Message 2 of 12 (458 Views)
Re : ModelSpace vs. PaperSpace Viewport
08-18-2013 11:03 PM in reply to: junoj
Look at the TILEMODE and CVPORT sytem variables.
The TileMode sysvar (or Database property) indicates if the Model layout si active (1) or any other layout 0.
If TileMode = 0, the CVPORT sysvar returns the current viewport number, 1 is the number of the layout viewport and indicates the Paper space is active. Values greater than 1 indicates a floating viewport is active (Model space through the viewport).
Gilles Chanteau
Distinguished Mentor
BlackBox_
Message 3 of 12 (431 Views)
Re: ModelSpace vs. PaperSpace Viewport
08-19-2013 05:50 AM in reply to: junoj
Quick example:
// <snip>
// using transaction (tr) ObjectId spaceId; if (1 == System.Convert.ToInt32(Application.GetSystemVariable("CVPORT"))) spaceId = SymbolUtilityServices.GetBlockPaperSpaceId(db); else spaceId = SymbolUtilityServices.GetBlockModelSpaceId(db); BlockTableRecord btr = tr.GetObject(spaceId, OpenMode.ForWrite) as BlockTableRecord;
// do something useful
// commit()
// <snip>
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
junoj
Message 4 of 12 (419 Views)
08-19-2013 08:37 AM in reply to: junoj
Thank you very much Gilles and BlackBox. Both of your methods will work providing that I have the drawing open with Autocad. Unfortunately I am accessing the dwg remotely without opening the application, so the application object is not available to me.
*Expert Elite*
_gile
Message 5 of 12 (407 Views)
08-19-2013 11:00 AM in reply to: junoj
            if (db.TileMode)
            else
Gilles Chanteau
junoj
Message 6 of 12 (403 Views)
08-19-2013 12:17 PM in reply to: _gile
Thank you very much Gilles!!!
junoj
Message 7 of 12 (392 Views)
08-19-2013 03:14 PM in reply to: _gile
One more quick question Gilles, Is it possible to get the ID of the Layout when a viewport is active - looking at the model space? When I try 'CurrentSpaceId' i get the ID of the model space.
BlackBox_
Message 8 of 12 (344 Views)
08-20-2013 05:41 AM in reply to: junoj
Perhaps this excerpt from the developer documentation will help:
 http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-2CEED409-0E15-4F48-9AA1-D12D246E27DB...
Identify and Manipulate the Active Viewport (.NET) :
The active viewport is represented in the Viewports table by a record named "*Active", which is not a unique name as all tiled viewports currently displayed on the Model tab are named "*Active". Each tiled viewport that is displayed is assigned a number. The number of the active viewport can be obtained by:
  • Retrieving the value of the CVPORT system variable
  • Using the ActiveViewportId property of the Editor object to get the object id for the active viewport and then open the Viewport object to access its Number property
Once you have the active viewport, you control its display properties, enable drafting aids for the viewport such as grid and snap, as well as the size of the viewport itself. Tiled viewports are defined by two corner points: lower-left and upper-right. The LowerLeftCorner and UpperRightCorner properties represent the graphic placement of the viewport on the display.
junoj
Message 9 of 12 (330 Views)
08-20-2013 07:56 AM in reply to: junoj
Thank you BlackBox. My understanding is that the CVPORT variable is for viewports. What I am trying to obtain is the CTAB system variable. The CTAB variable has the name of the current tab regardless if one of the viewports is active.
I am able to obtain the CTAB  variable via the GetSystemVariable , but I am having a hard time finding a way to access same variable without opening the drawing.
I think CTAB is a very elegant solution, providing I can find a way to obtain the variable.
BlackBox_
Message 10 of 12 (318 Views)
08-20-2013 11:36 AM in reply to: junoj
Sorry for my misunderstanding... Consider LayoutManager.Current.CurrentLayout as Viru demonstrates in this DevBlog article:
http://adndevblog.typepad.com/autocad/2012/06/identifying-active-space-and-active-layout.html
[Edit] - Forgot to mention using the LayoutManager's GetLayoutId() Method (using CurrentLayout as the string parameter)
Cheers
Announcements
Need installation help?
