.NET
Modeless problem
8 REPLIES 8
Message 1 of 9
610 Views, 8 Replies
Modeless problem
Hi all!
I have a little problem : when I minimize the autoCAD window, I still see my modeless dialogs in the desktop. ;(
Please is there a way to minimize them with their parent window(AutoCAD), or just close them. Something like events perhaps?
Sorry for my English and thanks in advance for anyone who can help.
Aymen,
8 REPLIES 8
Message 2 of 9
use ShowModelessDialog of the Application object.
wrote in message news:5328784@discussion.autodesk.com...
Hi all!
Aymen,
Message 3 of 9
Hi Paul!
The problem is that I'm using ShowModelessDialog...
Aymen,
Message 4 of 9
I don't know what's up. It works for me. Post the code you're using.
Also, do search for "ShowModelessDialog" Tony posted a nice example
which implements a singleton method.
wrote in message news:5328833@discussion.autodesk.com...
Hi Paul!
Aymen,
Message 5 of 9
We're not fortune tellers with crystal balls, so
we don't know what your code is doing without
seeing a reproducible case.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Hi Paul!
Aymen,
Message 6 of 9
And I thought you could do all. I need to
go rethink the universe. 🙂
"Tony Tanzillo" wrote in message
news:5330428@discussion.autodesk.com...
Hi Paul!
Aymen,
Message 7 of 9
Try using second ShowModelessDialog constructor, passing ACAD window handle
as it's second parameter.
Maksim Sestic
Hi all!
Aymen,
Message 8 of 9
Hi all,
Sorry, I had some personal problems...(Now, it's Ok!)
This is the code, it is supposed to work like the acet-ui-status (a lisp command displaying a modeless dialog with custom text).
First file :
using System;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
namespace TestNamespace
public class TestUiStatusClass
//Importing necessary DLLS
[DllImport("USER32.DLL")]
public static extern IntPtr SetFocus(System.IntPtr hwnd);
UiStatusForm TestForm = new UiStatusForm();
//Command Calls
[CommandMethod("UiStatus")]
public void showErr()
if (TestForm.Visible)
{ TestForm.Hide(); }
else
IWin32Window owner = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Window;
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(owner, TestForm);
TestForm.Location = new System.Drawing.Point(200, 200);
Label label1 = new System.Windows.Forms.Label();
Label label2 = new System.Windows.Forms.Label();
//// label1
label1.AutoSize = true;
label1.BackColor = System.Drawing.Color.Transparent;
label1.Font = new System.Drawing.Font("Microsoft Sans Serif", 14.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
label1.Location = new System.Drawing.Point(70, 9);
label1.Name = "label1";
label1.Size = new System.Drawing.Size(116, 24);
label1.TabIndex = 0;
label1.Text = "MessageTitle : ";
TestForm.Controls.Add(label1);
//// label2
label2.AutoSize = true;
label2.BackColor = System.Drawing.Color.Transparent;
label2.ForeColor = System.Drawing.Color.White;
label2.Location = new System.Drawing.Point(80, 24);
label2.Name = "label2";
label2.Size = new System.Drawing.Size(273, 13);
label2.TabIndex = 1;
label2.Tag = "";
label2.Text = "\nTest text";
TestForm.Controls.Add(label2);
IntPtr hwnd = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Window.Handle;
SetFocus(hwnd);
Second file:
/// Summary description for ModalForm.
public class UiStatusForm : System.Windows.Forms.Form
//private IContainer components;
public UiStatusForm()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
private System.ComponentModel.Container components = null;
/// Clean up any resources being used.
protected override void Dispose(bool disposing)
if (disposing)
if (components != null)
components.Dispose();
base.Dispose(disposing);
#region Windows Form Designer generated code
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
private void InitializeComponent()
System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(UiStatusForm));
this.SuspendLayout();
// UiStatusForm
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.AutoSize = true;
this.AutoValidate = System.Windows.Forms.AutoValidate.EnablePreventFocusChange;
this.BackColor = System.Drawing.Color.Red;
this.BackgroundImage = ((System.Drawing.Image)(resources.GetObject("$this.BackgroundImage")));/// place any Background Image you want
this.BackgroundImageLayout = System.Windows.Forms.ImageLayout.None;
this.ClientSize = new System.Drawing.Size(270, 70);
this.ForeColor = System.Drawing.Color.White;
this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.None;
this.MaximumSize = new System.Drawing.Size(320, 640);
this.MinimumSize = new System.Drawing.Size(270, 70);
this.Name = "UiStatusForm";
this.Opacity = 0.9;
this.ShowIcon = false;
this.ShowInTaskbar = false;
this.StartPosition = System.Windows.Forms.FormStartPosition.Manual;
this.ResumeLayout(false);
#endregion
Thanks in advance and sorry again.
Aymen,
Message 9 of 9
Did you try with:
size=2>Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(Application.MainWindow,
TestForm);
Maksim Sestic
Hi all,
Sorry, I had
with custom text).
First file
using
System;
using
using
namespace
TestNamespace
   public class
TestUiStatusClass
DLLS
UiStatusForm();
    //Command
Calls
       public void
showErr()
           if
(TestForm.Visible)
{ TestForm.Hide();
else
TestForm);
200);
Label label1 = new
Label label2 = new
label1
label1.AutoSize =
true;
label1.BackColor =
((byte)(0)));
9);
label1.Name =
"label1";
24);
label1.TabIndex =
0;
label2
label2.AutoSize =
true;
label2.BackColor =
label2.ForeColor =
24);
label2.Name =
"label2";
13);
label2.TabIndex =
1;
label2.Tag =
text";
IntPtr hwnd =
SetFocus(hwnd);
Second
file:
using
<summary>
</summary>
components;
        public
UiStatusForm()
support
// TODO: Add any
call
        private
/// <summary>
</summary>
        protected
disposing)
            if
(disposing)
if (components !=
null)
<summary>
modify
</summary>
private void
UiStatusForm
13);
this.AutoSize =
true;
this.AutoValidate =
this.BackColor =
want
70);
this.ForeColor =
640);
70);
this.Name =
"UiStatusForm";
this.Opacity =
0.9;
this.ShowIcon =
false;
false;
#endregion
Aymen,
”Boost
