Anyone know the equivalent of getting a AcGsModel with a render type of kDirect similar to that of the old BlockView example in ObjectArx. The function used the AcGsClassFactory::createModel(...) but I cannot seem to find an equivalent to this in .Net.
I am currently using an in-memory Database to display graphical objects. Now I want to add "Ghost" objects to the View where they are not added to the Database and displayed over-top of the database resident objects. How can I accomplish this in .Net.
Any tips would be appreciated.
Mike
I have, and based my view on that. The difference is that the BlockView .Net example does not include the orbit object which the original block view has.
- Mike
It seems like the transient api is definitely the way for you... Check out Keans blog http://through-the-interface.typepad.com/through_the_interface/2011/03/using-transient-graphics-to-s...
In terms of creating an AutoCAD model using .NET, here's some code that might be useful to someone. I wrote it pretty quickly so please excuse any bugs, logic errors.
// command to generate DWG and Block thumbnail bitmaps
// by Fenton Webb, DevTech, 24/1/2013
[CommandMethod("GENERATETHUMBS")]
public void GenerateThumbnailBitmaps()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
// get the output path for the bitmaps
PromptStringOptions opts = new PromptStringOptions("\nEnter output path : ");
opts.AllowSpaces = true;
PromptResult res = ed.GetString(opts);
// if ok
if (res.Status == PromptStatus.OK)
try
// make sure the folder exists
DirectoryInfo outputPathInfo = new DirectoryInfo(res.StringResult);
if (outputPathInfo.Exists)
Point2d screenSize = (Point2d)Application.GetSystemVariable("SCREENSIZE");
// set up the image sizes
int width = (int)screenSize.X;
int height = (int)screenSize.Y;
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
// get the dwg file name
FileInfo dwgPath = new FileInfo(doc.Name);
// get the document graphics system manager
Manager gsm = doc.GraphicsManager;
// construct the default filename prefix and path
string defaultPath = outputPathInfo.FullName + "\\" + dwgPath.Name.Replace(".dwg", " ");
// first generate the MS screen shot
View acadView = gsm.GetGsView(2, true);
Rectangle rect = new Rectangle(0, 0, width, height);
using (Bitmap msBmp = acadView.GetSnapshot(rect))
msBmp.Save(defaultPath + " MS.bmp");
// now set the block sizes to something standard
width = 800;
height = 600;
// now generate the layout images
// first remember the current layout
string currentLayout = LayoutManager.Current.CurrentLayout;
// now lets loop the layouts, open the layout dict
using (DBDictionary layoutDict = db.LayoutDictionaryId.Open(OpenMode.ForRead) as DBDictionary)
// now iterate the layouts and get the names
foreach (DBDictionaryEntry layoutEntry in layoutDict)
string layoutName = layoutEntry.Key;
LayoutManager.Current.CurrentLayout = layoutName;
using (Bitmap layoutBmp = doc.CapturePreviewImage((uint)width, (uint)height))
layoutBmp.Save(defaultPath + " " + layoutName + ".bmp");
/*View layoutView = gsm.GetGsView(1, true);
using (Bitmap layoutBmp = layoutView.GetSnapshot(rect))
layoutBmp.Save(defaultPath + " " + layoutName + ".bmp");*/
// restore the original layout
LayoutManager.Current.CurrentLayout = currentLayout;
// now create an off screen device
using (Device offDevice = gsm.CreateAutoCADOffScreenDevice())
// now size the device
offDevice.OnSize(new System.Drawing.Size(width, height));
// now create the view
using (View view = new View())
// add the new view object to the device
offDevice.Add(view);
// update it
offDevice.Update();
// ok now create the model
using (Model model = gsm.CreateAutoCADModel())
using (BlockTable bt = db.BlockTableId.Open(OpenMode.ForRead) as BlockTable)
// now iterate through our block tables
foreach (ObjectId id in bt)
// open the btr for read
using (BlockTableRecord btr = id.Open(OpenMode.ForRead) as BlockTableRecord)
// get the name of the block for the BMP file name
string btrName = btr.Name;
// add the btr to the view
view.Add(btr, model);
try
// get the extents of the btr
Extents3d extents = new Extents3d();
extents.AddBlockExtents(btr);
// now zoom extents of the view
view.ZoomExtents(extents.MinPoint, extents.MaxPoint);
// finally, construct the filepath
string imagePath = defaultPath + btrName + " Block.bmp";
// clean up the path
imagePath = imagePath.Replace("*", "");
// snap the image
using (Bitmap blockBmp = view.GetSnapshot(rect))
blockBmp.Save(imagePath);
catch
// reset the view for the next iteration
view.EraseAll();
offDevice.EraseAll();
else
ed.WriteMessage("\nThe Path is invalid: " + res.StringResult);
catch
ed.WriteMessage("\nThe Path cannot be written to: " + res.StringResult);
