.NET
deepakpuri
Message 1 of 6 (234 Views)
missing an autocad reference
234 Views, 5 Replies
07-18-2012 03:46 AM
I am Programming with Visual Studio 2010.(VB.NET)
I am facing a problem that everytime I write "Dim Line1 as AcadLine" it shows error, whereas if I write "Dim Line1 As Autocad.Acadline" the code works fine.
Pls suggest which reference  am I missing ? (I would like to write "Dim Line1 as AcadLine".)
Deepak
Alfred.NESWADBA
Message 2 of 6 (224 Views)
Re: missing an autocad reference
07-18-2012 06:31 AM in reply to: deepakpuri
then place on top of your code-file this statement
Imports Autodesk.AutoCAD.Interop.Common
...plus do some readme in helps about Framework and Namespaces :smileywink:
- alfred -
Alfred NESWADBA
deepakpuri
Message 3 of 6 (205 Views)
07-19-2012 02:06 AM in reply to: Alfred.NESWADBA
I am doing that already
I was missing the new keyword
Public Cadapp as New Acadapplication  :smileywink:
deepakpuri
Message 4 of 6 (202 Views)
07-19-2012 02:13 AM in reply to: deepakpuri
sorry the previuos reply was in some other context, I am still looking for the solution & will get back as soon as I find it
Alfred.NESWADBA
Message 5 of 6 (197 Views)
07-19-2012 02:53 AM in reply to: deepakpuri
then try this statement just to make sure you have all necessary references inluded:
Dim Line1 as Autodesk.AutoCAD.Interop.Common.AcadLine
Does that also result in an error? If so you are missing the reference to the COM-objects:
Autodesk.AutoCAD.Interop.Common.dll
- alfred -
Alfred NESWADBA
New Member
rcloud85
Message 6 of 6 (44 Views)
07-30-2014 11:19 AM in reply to: Alfred.NESWADBA
Can you tell me what the 'Assembly' or COM is that I need to include in my VS2012 project?
I'm needing to open/save/close multiply dwg files programmatically, in order to update them to our latest version, as well as run a custom LISP routine upon each dwg to extract data from the drawing...
Rick
