.NET
Distinguished Contributor
HJohn1
Message 1 of 5 (224 Views)
Mirror BlockReference on UCS
224 Views, 4 Replies
08-09-2013 11:15 AM
I having problems mirroring blockreferences when the active coordinate system is not the WCS.  We are mirroring through the base point of the blockreference.  On the WCS I am doing this:
Pt = Blk.Position.Add(New Vector3d(0, 50, 0))
lin = New Line3d(Blk.Position, Pt)
Blk.TransformBy(Matrix3d.Mirroring(lin))
 For the WCS it works very well, however when the current coordinate system is a UCS then it does not work.  I have tried this:
mtrx = Ed.CurrentUserCoordinateSystem
Dim vt As New Vector3d(0, 50, 0)
'vt.TransformBy(mtrx)
Pt = Blk.Position.Add(vt)
lin = New Line3d(InsPt, Pt)
lin.TransformBy(mtrx)
 I think my problem is the end point of the line, pt.  I tried to transform the vt but that does not work either.  Can someone please help me here.  Thanks in advance.
If I don't misunderstand, you want to mirror a block about a line parallel to the current UCS Y axis which containd the block position.
Vector3d vt = Vector3d.YAxis.TransformBy(ed.CurrentUserCoordinateSystem)
Blk.TransformBy(Matrix3d.Mirroring(new Line3d(Blk.Position, Blk.Position + vt)))
_gile
Message 2 of 5 (198 Views)
Re : Mirror BlockReference on UCS
08-10-2013 03:48 AM in reply to: HJohn1
Gilles Chanteau
HJohn1
Message 3 of 5 (189 Views)
08-10-2013 05:54 AM in reply to: _gile
Thank you very much _gile this is exactly what I was trying to do.  I was going to use the Matrix3d.Mirroring(Plane) method.  How do I get the Yaxis Plane of the current coordinate system?
_gile
Message 4 of 5 (180 Views)
Re : Re : Mirror BlockReference on UCS
08-10-2013 08:04 AM in reply to: HJohn1
Plane plane = new Plane(br.Position, Vector3d.XAxis.TransformBy(ed.CurrentUserCoordinateSystem));
Blk.TransformBy(Matrix3d.Mirroring(plane));
Gilles Chanteau
HJohn1
Message 5 of 5 (137 Views)
08-12-2013 06:25 AM in reply to: _gile
Thank you very much _gile.
