.NET
Valued Contributor
HelloWorlddd
Message 1 of 6 (193 Views)
Metric and imperial
193 Views, 5 Replies
04-01-2014 05:30 AM
My command is create for metric drawings, but sometimes it will execute in the imperial drawing, so I need to know if a drawing is a metric drawings or imperial drawing, and then set diferent value for differet drawings.
How do I know that relevant information, thanks for any help.
The below pricture show the two different drawing.
mzakiralam
Message 2 of 6 (187 Views)
Re: Metric and imperial
04-01-2014 05:45 AM in reply to: HelloWorlddd
try to get the system variable DIMLUNIT. It will return a integer. on the basis of integer you will be able to get which kind is unit setting is there. Suppose if it returns 2 then unit is decimal. If returns 5 then setting is Architectural. Please see below screen shot for details
SENL1362
Message 3 of 6 (159 Views)
04-01-2014 12:07 PM in reply to: HelloWorlddd
measurement=0 or 1(for metrics)
Valued Contributor
HelloWorlddd
Message 4 of 6 (133 Views)
04-02-2014 05:21 AM in reply to: mzakiralam
I meet some problem, I will get 2 when use the below statements:
 int DIMLUNIT = System.Convert.ToInt32(Application.GetSystemVariable("DIMLUNIT"));
Application.ShowAlertDialog(DIMLUNIT.ToString());
Then I change the Drawing Units from Decimal to Architectural, I will get 2 also, I don't know why.
I just want to get 2 when the Drawing Units is Decimal and get 4 when the  Drawing Units is Architectural,
How should I do?
mzakiralam
Message 5 of 6 (131 Views)
04-02-2014 06:09 AM in reply to: HelloWorlddd
HI ,
sorry it was my mistake. "DIMLUNIT" is supposed to be used for dimension only. you have to use "LUNITS" in this case.
Valued Contributor
HelloWorlddd
Message 6 of 6 (126 Views)
04-02-2014 07:32 AM in reply to: mzakiralam
Thank you very much
