.NET
Merging two cells in a row?
3 REPLIES 3
chikito1990
1382 Views, 3 Replies
Hi all,
I am trying to merge two cells in one but i cannot find proper method to do that. Any suggestions?
Example:
I am creating a table with dynamic number of rows and columns:
 for (int i = 3; i < tbRight.NumRows; i++)
                    for (int j = 0; j < tbRight.NumColumns; j++)
                        if (num2 == numCircles - 1)
                            Cell c = new Cell(tbRight, i, j);
                            c.TextHeight = 450;
                            tbRight.SetTextString(i, j, (num2 + 1).ToString() + "# - " + rightConn[num2]);
                            num2++;
                        else if (num2 > numCircles - 1)
                        else
                            c.TextHeight = 450;
                            num2++;
 First row of the table is the header and i have two free rows with two columns each. I want to merge all of them to look like one row.
On the other hand, is it possible to align the text in the table in the middle and also the vertical align to be in the middle.
Thank you in advance!
3 REPLIES 3
hgasty1001
in reply to: chikito1990
You can merge cell ranges, like this:
Private Sub FormatCells(ByVal ft As Table, ByVal row As Integer, ByVal start As Integer, ByVal fend As Integer)
        Dim rc As CellRange = CellRange.Create(ft, row, start, row, fend)
        ft.MergeCells(rc)
    End Sub
Gaston Nunez
gvgbabu
in reply to: hgasty1001
hi
i am getting the error Type 'CellRange' is not defined when i am using cellrange for merging two cells.
i am using Autocad 2007 and Vb.net 2005.
please help me how to merge two cells in a table using cellrange and table.mergecells()
gvgbabu
in reply to: gvgbabu
please help me how to merge two cells in a row in vb.net 2005
”Boost
