.NET
0 Kudos
Post 1 of 1
Merge ribbon tab
128 Views, 0 Replies
06-20-2012 06:10 AM
When i start Autocad and then the command 'SRT' then nothing happens
When i edit a block , and the tab "Block Editor - Close Contextual Merged Tab" has been visible then the command 'SRT' works and shows me the merged tab.
Does anyone knows what i have to do to make the command work even when te merged tab has not been visible.
    <CommandMethod("SRT")> Sub setRibbonTab()
        Dim RibContr As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        For Each rib In RibContr.Tabs
            Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & rib.Name)
            If rib.Name = "Block Editor - Close Contextual Merged Tab" Then
                rib.RibbonControl.ShowContextualTab(rib, True, True)
            End If
        Next
        RibContr.UpdateLayout()
    End Sub
