Running MEP Building Design Suite Standard 2015, Win 8.1 64 bit. (also broke under Win 7 64 bit).
I have several VB Dot Net programs that run fine with MEP 2015 and SP1 but when I upgraded to SP2 I now get the following VB Dot Net error :
Could not load file or assembly AecArchMgd, Version=7.7.104 on one machine, and on another I got Could not load file or assembly AecArchMgd, Version=7.7.208.
I have attached a capture of the error message.
We have a workaround solution for our issue but something definately changed in SP2.
In the 2 programs that we have been getting this error with we were demand loading another dll using "system.reflection.assembly.loadfile("filename")".
We commented this line out, rebuilt the release, then restarted MEP and BEFORE running the program that was erroring, we manually netloaded the program that we were previously demand loading.
Then when the program was run it ran without errors.
So it seems that demand loading with "system.reflection.assembly.loadfile("filename")" no longer loads the file under SP2 for some reason.
Our workaround is simply to netload the required Dll's with lisp code added to our "Acad.lsp" file.
For future reference, Is there a different way that demand loading should be done now?
I'm not totally aware of MEP BDS, but as your query posted in AutoCAD .NET , I take bit liberty to put few comments.
Yes ,within ACAD -SP2 we are not resolving assemblies ,developers need to hook an assembly event , find & send the necessary assemblies when the particular event is called.
For example:
Private Shared Function OnAssemblyResolve(sender As Object, args As ResolveEventArgs) As Assembly Dim assembly As Assembly = Nothing Dim assems As [Assembly]() = AppDomain.CurrentDomain.GetAssemblies() Dim shortName As String = args.Name.Split(New [Char]() {","}).GetValue(0) ' Threadsafe is some dependent DLL Dim threadSafe As String = "ThreadSafe" 'check that the assembly being asked for is one of ours and if it is not, then return nothing If shortName <> threadSafe Then Return assembly End If For Each assem In assems If assem.GetName.Name = shortName Then Return assem End If Next assem 'if assembly is not loaded ,we 'll explictly load this may not be required Dim an = New AssemblyName(args.Name) If an.Name <> args.Name Then assembly = DirectCast(sender, AppDomain).Load(an.Name) End If Return assembly End Function
If you feel ,your issue is particular to MEP BDS ,try to post in the relevant forum page.
Thank you.
Hi Thanks for your clarification ,
I understand that AutoCAD is not able resolve its vertical DLL's[AecArchMgd.dll] , my earlier answer was on plain vanilla autocad to resolve user created DLL's[ DLLs generated using objectARX .NET API].
I think it is better you post this query on ACA forum ,
http://forums.autodesk.com/t5/autocad-architecture/ct-p/56
