.NET
Material Object (render) with c#
2 REPLIES 2
base2
432 Views, 2 Replies
Hi guys..
I'm going to build with code a material..in c#.
I have a serious problem with the diffuse assignment...
MaterialMap constructor assigned with "New" don't run correctly...IMHO.
please take a look at the material3.jpg !
Here the constructor MaterialMap with the parameters "source = 1" (file) perform the constructor...and the result is source = "scene" (0)
So i'm not able to use a texture for the Diffuse material's component 😞 😞
What can I do ?
is there a my wrong ? where is it ? I ' can't see it!
what
2 REPLIES 2
base2
in reply to: base2
please take a look here! this is my debug window
in reply to: base2
This is kindof late, however, somebody searching for the answer in the future could make use of this:
Don't use MaterialTexture, use:
GraphicsInterface.ImageFileTexture
if the diffuse source is from an image file. You would use the MarbleTexture class for marble, and WoodTexture class for wood.
”Boost
