.NET
Make a wblock using selection set with filter and save the wblock to another dwg
1 REPLY 1
587 Views, 1 Reply
Hi:
I don't know what i am doing wrong i am trying to make a wblock using
selection set with filter and i want to save this wblock to a dwg file as to
use it after that in the code.
Here is the code i wrote:
Public Function ssGetFilter(ByVal strPannelID As String, ByVal strWblockPath
As String, ByVal strPannelName As String)
Try
Dim ed As Editor =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim values() As TypedValue = { _
New TypedValue(1001, strPannelName), _
New TypedValue(1001, strPannelID)} ', _
Dim sfilter As New SelectionFilter(values) ' Create the filter using our
values...
Dim res As PromptSelectionResult = ed.SelectAll(sfilter)
If Not res.Status = PromptStatus.OK Then Return Nothing
Dim i As Integer
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
Dim idarray As ObjectId() = SS.GetObjectIds()
Dim objIdColl As New ObjectIdCollection
For i = 0 To idarray.Length - 1
objIdColl.Add(idarray(i))
Next
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tempDb As New Autodesk.AutoCAD.DatabaseServices.Database(False, True)
db.Wblock(tempDb, objIdColl, New Point3d(0, 0, 0),
DuplicateRecordCloning.Ignore)
tempDb.SaveAs(strWblockPath, DwgVersion.Current)
tempDb.Dispose()
db.Dispose()
Catch ex As Exception
MsgBox(ex.Message)
End Try
End Function
Thanks in advance."
Nermeen Bakr
Project Manager
MCS (Modern Computing Services)
Website: http://www.mcsoil.com
Phone: +2 02 4036520 /+202 4051129
Fax: +2 02 4040503
1 REPLY 1
Dear Mr.Nermeen Bakr,
In the first place I would thank you that with slight modification in your code I was able to solve my issue of generating wblock. The following code is working fine now :
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
'custom
Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports DBTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager
#Region "Draw a wblock"
_
Public Sub AddNewBTRB()
'added new
Dim db As Database = New Database(), _
tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager, _
t As Transaction = tm.StartTransaction(), _
bt As BlockTable = tm.GetObject(db.BlockTableId, OpenMode.ForWrite), _
btr As BlockTableRecord = tm.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim myDwg As Document
Dim myBT As BlockTable
myDwg = Application.DocumentManager.MdiActiveDocument
myTransMan = myDwg.TransactionManager
myTrans = myTransMan.StartTransaction
'Open the database for Write
myBT = myDwg.Database.BlockTableId.GetObject(OpenMode.ForWrite)
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim opt As New EditorInput.PromptSelectionOptions
Dim optR As EditorInput.PromptSelectionResult
optR = ed.GetSelection(opt)
If optR.Value Is Nothing = False Then
Dim I As Long
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = optR.Value
For I = 0 To idarray.Length - 1
objIdColl.Add(idarray(I))
Next
Dim tempDb As Database = Application.DocumentManager.MdiActiveDocument.Database
tempDb.Wblock(db, objIdColl, New Point3d(0, 0, 0), DuplicateRecordCloning.Ignore)
db.SaveAs("c:\test1.dwg", DwgVersion.Current) 'added new
myTrans.Commit()
'Dispose of the Transaction Objects
myTrans.Dispose()
myTransMan.Dispose()
End Sub
#End Region
Hope the above will solve your issue.
Sandeep Banerjee, New Delhi, India
”Boost
