.NET
Lots of transient graphics hang orbit
11 REPLIES 11
Message 1 of 12
JamesMaeding
1102 Views, 11 Replies
I have a tin surface with 16,000 triangles, and am displaying the edges as transients of 3d lines.
I get about 26,000 of those for the 16k triangles.
Yes, I did weed duplicates of adjacent triangle edges, so cannot reduct eth edge count.
When I orbit, it hangs for about 10x longer than if those edges were real entities.
Its like 15 seconds before I can drag the view a bit.
Why would transients be causing such a slowdown compared to real entities?
my code for making the transient is very boring:
ln = new Line(pts[i], pts[i + 1]);
ln.SetDatabaseDefaults();
 I add that line to transientmanager:
tm.AddTransient(trEnt.Entity, TransientDrawingMode.DirectShortTerm, 0, trEnt.ViewportNumbers);
 I have a wrapper object I call trEnt that I use but its properties feed the right values in.
Does the fact that that I used DirectShortTerm have any effect?
What should I be using for better performance?
I do want to see the items in orbit, not erase them and redraw after.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
11 REPLIES 11
Message 2 of 12
moogalm
in reply to: JamesMaeding
Hi ,
Can you share a sample project to demonstrate said behavior , meanwhile you can try Highlight as transient drawing mode at your end ,check if that change anything.
Thank you!
Message 3 of 12
JamesMaeding
in reply to: moogalm
something like:
[CommandMethod("TTR2")]
    public void TestTransGraphics2() {
      TransientManager tm = TransientManager.CurrentTransientManager;
      double y = 0.0;
      for (int i = 0; i < 500000; i++) {
        AcDb.Line ln = new AcDb.Line(new Point3d(0.0, y, 0.0), new Point3d(5.0, y, 0.0));
        transients.Add(ln);
        tm.AddTransient(ln, TransientDrawingMode.Main, 128, new IntegerCollection());
        y = y + 1.0;
then to get rid of:
[CommandMethod("TTRR1")]
    public void TestRemoveTransGraphics() {
      tm.EraseTransients(TransientDrawingMode.Main, 128, new IntegerCollection());
      //for (int i = 0; i < transients.Count; i++) {
      //    Entity ent = transients[i];
      //    tm.EraseTransients(TransientDrawingMode.DirectShortTerm, 0, new IntegerCollection());
      //    ent.Dispose();
      //    ent = null;
 you can see the commented out portion that would do things one by one. I tried both and both are pretty slow.
Message 4 of 12
moogalm
Hi ,
I don't see any performance down in the application , I've tested with the following code on ACAD 2015-SP2 ,WIN7X64,16GB RAM, can you let me know you system configuration , just to check whether system config has any impact.
DBObjectCollection _markers = null;
       [CommandMethod("TTRC")]
       public void ClearTransientGraphics()
           IntegerCollection intCol = new IntegerCollection();
           tm.EraseTransients(TransientDrawingMode.DirectShortTerm, 128, intCol);
           double y = 0.0;
           _markers = new DBObjectCollection();
               Line ln = new Line(new Point3d(0.0, y, 0.0), new Point3d(5.0, y, 0.0));
               _markers.Add(ln);
               tm.AddTransient(ln, TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection());
               y = y + 1.0;
Message 5 of 12
JamesMaeding
those specs are similar to mine. I have a Dell Precision 6800 laptop, so its better hardware than the average cad user for my office at least.
Can you comment on how long it takes to:
display the transients
erase the transients
actually drag the view once you run orbit command - there is always some regen-like delay.
I'll do the same. I'm very happy to hear you are not seeing the lockups, love it when I'm the problem not the software 🙂
Message 6 of 12
JamesMaeding
So I ran a few tests in vanilla acad 2015, sp2. I am finding for acad:
2 seconds to display 50k transients - uses 600k ram
2 seconds to delete - does not release the 600k ram. Each time I display the transients it goes up 600k.
locks on orbit no matter what, CPU is at 13%, and memory jumps to about 1gb
are you saying command "orbit" does not lock you up? How much memory did it use by the time you could drag the cursor?
Interestingly, if I make real lines (using only one transaction...) instead of transients, it takes:
4 seconds to draw lines
orbit takes forever or locks on them also, cpu goes to 10% and memory jumps to 13gb! wow, never seen that before.
So just trying to understand if you see anything like me for orbit.
oddly enough, in bricscad, the display time of transients is almost the same, and orbit is instant. Erasing the transients locks it up.
another odd thing is you can zoom extents with bricscad transients, acad ignores them.
Message 7 of 12
JamesMaeding
that memory increase of 600k each time I run was because
tm.EraseTransients does not dispose of the ent.
after tm.EraseTransients I did:
 //netload tm.EraseTransients(TransientDrawingMode.DirectShortTerm, 0, new IntegerCollection());
 ent.Dispose();
 ent = null;
and that increasing emory issue goes away.
It does not affect the orbit issue, which is the main thing I care about.
I guess a fundamental question is if transients are lighter weight than drawn entities, for the display. I can't tell since orbit lock on a lot of them.
Message 8 of 12
moogalm
I completely focussed on generation of transients consuming time , and missed the orbit part. Sorry about that I can repro and performance down.
Let me do few more tests and will get back to you.
Thanks for your patience.
Message 9 of 12
moogalm
I have tested using C++ API , at least application doesn't hang there, however there is bit performance lag between DB entities and transients.
Using .NET API ,I can reproduce the behavior , I will check with engineering colleagues about this.
Meanwhile can you try using C++ code and let me know .
 /*global*/
static AcArray<int> viewportNumbers;
static AcArray<AcDbEntity*> _markers;
static void ClearTransientGraphics()
    AcGiTransientManager* pTransientManager = acgiGetTransientManager();
    int numOfMarkers = _markers.length();
    if (numOfMarkers > 0)
        for(int index = 0; index < numOfMarkers; index++)
            AcDbEntity *pMarker = _markers.at(index);
            pTransientManager->eraseTransient(
            pMarker,
            viewportNumbers
            delete pMarker;
        _markers.removeAll();
 static void ADSKMyGroupTTest()
	 AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase();
	 ClearTransientGraphics();
	 viewportNumbers.removeAll();
	 struct resbuf res;
	 acedGetVar(L"CVPORT", &res);
	 viewportNumbers.append(res.resval.rint);
	 double y = 0.00;
	 for(int i=0; i < 5000; ++i)
		 AcDbLine* marker = new AcDbLine(AcGePoint3d(0.0,y,0.0),AcGePoint3d(5.0,y,0.0));
		 pTransientManager->addTransient(marker,kAcGiDirectShortTerm,128,viewportNumbers);
		 _markers.append(marker);
		 y= y+1.0;
 static void ADSKMyGroupDTest()
	 double y = 0.00;
	 for(int i=0; i < 50000; ++i)
		 AcDbLine* marker = new AcDbLine(AcGePoint3d(50.0,y,0.0),AcGePoint3d(55.0,y,0.0));
		 marker->setColorIndex(3);
		if(appendEntity(pDb,marker)!= Acad::eOk)
		delete marker;
		else
		marker->close();
		y= y+1.0;
I have attached a video , in the video the entities in green are DB entities which behaves correctly ,transients also do with low performance ,however there no lock up when executing 3DORBIT
DemoVideo
Message 10 of 12
moogalm
I'm terrible and sorry ,
Scratch my previous post , in both C++ and .NET I can reproduce the problem, I've sent a mail across engineering team for insights.
But with DB entites application doesn't hang \or lock up while executing 3DORBIT.
Message 11 of 12
JamesMaeding
ahh, glad you are seeing it too, but wish it was just me 🙂
I'd like to figure this out, so lets keep on it.
I also do not get lockups with real drawn entities, but man its slow. I tweaked hardware accelleration and settings with no luck.
The interesting thing is whatever method the civil3d team uses to show tin surface triangle edges, its fast.
I am actually doing the same thing - writing tools that deal with triangles so showing lots of them is useful.
thx
Message 12 of 12
do you have a solution to solve the problem ?
I have a similar case : 80000 transients (AcDbSolid*) to display areas in the drawing.
And deleting the allocated pointers (used by transients) is VERY slow (C++ & ObjectARX)
Thank you.
Olivier BERRIER
www.geo-media.com
”Boost
