Hi! As I understood it is reccommended to use LoadOnCommandInvocation instead of LoadOnAutoCADStartup. Unfortunatelly I can not get it working. Here are my configuration files:
VB.NET
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime Namespace MYNAMESPACE Public Class MYPUBLICCLASS Public MyDoc As Document = Application.DocumentManager.MdiActiveDocument Public MyEd As Editor = MyDoc.Editor <CommandMethod("MYGROUP", "MYGLOBAL", "MYLOCAL", CommandFlags.Modal)> Public Sub MYSUB() MyEd.WriteMessage("running...") End Sub End Class End Namespace
PackageContents.xml
<?xml version="1.0" encoding="utf-8"?> <ApplicationPackage SchemaVersion="1.0" AppVersion="1.0.0" Author="MyAuthor" Name="MyAppName" Description="MyDescription" Icon="./Contents/icon.ico" HelpFile="./Contents/Help.pdf" ProductCode="{B6C18088-FEE9-46EF-9A62-10FEA0D388C5}" UpgradeCode="{A9E27EC5-5EEF-40A2-8156-CD106C89F55B}" > <CompanyDetails Name="MyName" Email="MyName@MyEmail.com" /> <Components> <RuntimeRequirements OS="Win64" Platform="Civil3D" SeriesMin="R20.0" SeriesMax="R20.0" /> <ComponentEntry AppName="MyAppName" ModuleName="./Contents/c3dx64.dll" LoadOnCommandInvocation = "True" LoadOnRequest="True"> <Commands GroupName="MYGROUP"> <Command Global="MYGLOBAL" Local="MYLOCAL" /> </Commands> </ComponentEntry> <ComponentEntry AppName="MyAppName" ModuleName="./Contents/c3dx64.cuix" /> </Components> </ApplicationPackage>
If I change LoadOnCommandInvocation to LoadOnAutoCADStartup then both MYGLOBAL and MYLOCAL commands are working. The same if I netload .dll manually. No luck with LoadOnCommandInvocation though. Any ideas would be appreciated!
Command: MYGLOBAL Unknown command "MYGLOBAL". Press F1 for help. Command: MYLOCAL Unknown command "MYLOCAL". Press F1 for help. Command: NETLOAD Command: MYGLOBAL running... Command: MYLOCAL running...
Does it work if you add an AppDescription="whatever" parameter to the <CommandEntry/> element?
This was the answer for me although I think Stephen meant <ComponentEntry> not <CommandEntry>
