.NET
Loading .NET DLL
2 REPLIES 2
MAHOD
376 Views, 2 Replies
Loading .NET DLL
Hi.
After installing SP1 2014 Autocad started to crash by loading DLL that contains Civil 3D libraries.
In the same time Civil3D works perfectly.
Is there a way to load some DLLs when starts Civill3d but not Autocad?
Thanks.
2 REPLIES 2
SENL1362
in reply to: MAHOD
You could do a NETLOAD from within a AcadDoc.lsp which is in a Acad Search Path for you're Civil Profile but not for you're regular AutoCAD.
philippe.leefsma
in reply to: SENL1362
That's a pretty good suggestion from SENL1362, another way could be to use the startup switch /b in your Civil shortcut to run a script that will netload dlls of your choice. The plain AutoCAD shortcut would have no script.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
”Boost
