.NET
Loading a Lisp file with VB.net
5 REPLIES 5
GeeHaa
7780 Views, 5 Replies
Is there a way to Load a lisp file from VB.net? All  I want to do is load it so its available at the command Prompt.
Thanks in Advance
5 REPLIES 5
BlackBox_
in reply to: GeeHaa
Have you tried SendStringToExecute() Method?
"How we think determines what we do, and what we do determines what we get."
GeeHaa
in reply to: GeeHaa
I only will do that as a last resort.
I tried
Autodesk.AutoCAD.Internal.Utils.RegisterLispCommand(LispCommandName, LispFilename)
But I get an eKeyNotFound error. I can't find any documentation about this method so I'm not sure what it does.
G
Virupaksha_aithal
in reply to: GeeHaa
It is better to avoid using any internal API, in this case RegisterLispCommand, when an alternative method (SendStringToExecute) is available. Internal methods will not have any documentation
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
ebikoba
in reply to: Virupaksha_aithal
How do you use the SendStringToExecute? I need an example please for loading a lisp routine.
Virupaksha_aithal
in reply to: ebikoba
Please refer https://forums.autodesk.com/t5/net/can-you-do-an-appload-from-a-c-program/td-p/5810305
”Boost
