.NET
Active Contributor
pva75
Message 1 of 2 (225 Views)
Load toolbar images from resource file
225 Views, 1 Replies
10-28-2012 10:25 AM
Is it possible to load toolbar images from resource file instad file from disk?
Now I did:
            AcadToolbar tb = mainGroup.Toolbars.Add("MyToolbar");
            tb.Visible = true;
            tb.Dock(AcToolbarDockStatus.acToolbarDockTop);
            AcadToolbarItem i1 = tb.AddToolbarButton(1, "Test", "TestButton", "\x1b\x1bTESTCMD ");
            i1.SetBitmaps(@"D:\Icons\BMP\test.bmp", @"D:\Icons\BMP\test.bmp");
I can't say that it's very useful. Is it possoble to load images from my plug-in DLL (resource file)?
Pavel.
ADN Support Specialist
Balaji_Ram
Message 2 of 2 (193 Views)
Re: Load toolbar images from resource file
10-30-2012 10:01 AM in reply to: pva75
Hi Pavel,
I dont think it is possible to do this using the COM API, but this can be done using the CUI API.
I have attached a document and sample projects from a Devnote which is yet to be migrated to a Devblog post.
Hope it helps.
Balaji
Developer Technical Services
Autodesk Developer Network
