.NET
load plot styles from server path
2 REPLIES 2
1149 Views, 2 Replies
Hi Guys,
please I did batch plot using C# I use specific plot style name, but I want to load the plot styles in the storred path on the server into a ListBox.
 please see the image attached.
thank you very much
2 REPLIES 2
norman.yuan
You can use COM API AcadPreferencesFiles.PrinterStyleSheetPath to get the folder path where *.ctb files are located.
If you use .NET 4, you can use dynamic without having to add reference to AutoCAD COM API interop:
C# code would be like:
dynamic cadPreferences=Application.Preference;
string folder=cadPreferences.PrinterStyleSheetPath;
string[] ctbFiles=System.IO.Directory.GetFiles(folder, "*.ctb");
Then you can use the file name array to populate listbox.
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
thank you very much,
it works fine.
”Boost
