.NET
osayed3202
Message 1 of 3 (231 Views)
load plot styles from server path
231 Views, 2 Replies
04-22-2014 06:05 PM
Hi Guys,
please I did batch plot using C# I use specific plot style name, but I want to load the plot styles in the storred path on the server into a ListBox.
 please see the image attached.
thank you very much
Best Regards
O.Sayed
CAD developer
You can use COM API AcadPreferencesFiles.PrinterStyleSheetPath to get the folder path where *.ctb files are located.
If you use .NET 4, you can use dynamic without having to add reference to AutoCAD COM API interop:
C# code would be like:
dynamic cadPreferences=Application.Preference;
string folder=cadPreferences.PrinterStyleSheetPath;
string[] ctbFiles=System.IO.Directory.GetFiles(folder, "*.ctb");
Then you can use the file name array to populate listbox.
norman.yuan
Message 2 of 3 (176 Views)
Re: load plot styles from server path
04-24-2014 12:04 PM in reply to: osayed3202
osayed3202
Message 3 of 3 (155 Views)
04-27-2014 11:42 AM in reply to: norman.yuan
thank you very much,
it works fine.
Best Regards
O.Sayed
CAD developer
