.NET
Load and run my dll from ACAD menu
4 REPLIES 4
269 Views, 4 Replies
Sorry, I'm sure this is simple but how do I load and run my .NET dll from
an ACAD 2006 menu? Tried all manner of lines but can't get it working.
^C^C-netload "D:/Dev Projects/VB Projects/_AutoCAD
Apps/MyTestApp01/bin/MyTestApp01.dll"; MyTestApp
TIA
Russ
4 REPLIES 4
OK Found it:
^C^C^C_filedia 0 _netload MyTestApp01.dll _MyTestApp _filedia 1
You could also use:
(command "netload" "MyTestApp")
You don't need to include .dll on the end of the file name.
Ben Rand
CAD Manager
CEntry Constructors & Engineers
brand@centry.net
"Russ Green" wrote in message
news:5040950@discussion.autodesk.com...
OK Found it:
alexandrescoelho
I can send the command by Autodesk.AutoCAD.Interop.AcadDocument.SendCommand("command") but it isn't execute the command, just write in the command line. How can I execute this command?
NathTay
Add a space at the end of the command string.
”Boost
