Good morning, I am trying to list the printers that are installed on my PC and tabem the plot style table (pen assignments), each in a popup_list, I have done the dialog box, just missing the lisp someone could give me an idea of how do.
thank you.
Solved by SENL1362. Go to Solution.
as a .NET solution this might help you:
using Autodesk.AutoCAD.PlottingServices; ...
[CommandMethod("LPC3")] public void ListPC3() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; PlotConfigManager.RefreshList(RefreshCode.All); PlotSettingsValidator plotSettingsValidator = PlotSettingsValidator.Current; try { var PlotDeviceList = plotSettingsValidator.GetPlotDeviceList().Cast<string>().ToList(); PlotDeviceList.ForEach(p => ed.WriteMessage("\n\t{0}", p));
var plotStyleList = plotSettingsValidator.GetPlotStyleSheetList()
.Cast<string>()
.Select(ctb => ctb.EndsWith(".ctb"))
.ToList();
