.NET
Listen for escape pressed
4 REPLIES 4
Fredrik.Larsen
1087 Views, 4 Replies
Hi
Is there a way to add a listener so I am told when escape(cancel command) is pressed? I want to create a cancel pressed event.
4 REPLIES 4
This way can help you:
How to implement a Windows Hook using acedRegisterFilterWinMsg in .NET
In WindowHookProc event handler you can check msg.Msg == WM_KEYDOWN (0x0100)  and msg.WParam == VK_ESCAPE (0x1B)
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks, that seems to work, but how do you unregister the listener? When escape is pressed I want to do something and then unregister the listener.
In order to unregister this event handler use function acedRemoveFilterWinMsg:
BOOL acedRemoveFilterWinMsg(
    const AcedFilterWinMsgFn pfn
In C# it is look like:
// For AutoCAD 2013 64 bit
// On previous versions, import from acad.exe (instead accore.dll)
[DllImport("accore.dll",  CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedRemoveFilterWinMsg@@YAHQ6AHPEAUtagMSG@@@Z@Z")]
private static extern int acedRemoveFilterWinMsg( WindowHookProc callBackFunc );
Expert Elite Member
Thank you very much.
”Boost
