.NET
List of Layer States
2 REPLIES 2
flongsworth
480 Views, 2 Replies
Somebody!. How can I simply get a list of the Existing Layer States in a dwg. It's pretty simple to do in VBA, just get the "ACAD_LAYERSTATES" dictionary and get the name property of each Xrecord. What is the .net equivalent.
2 REPLIES 2
in reply to: flongsworth
Why not just use com interop and do it the same way as you would with VBA
flongsworth
Yes, you are absolutely right. Here is the code that worked for me just in case somebody runs across the same issue. Thanks again Mark!
I hope the copy and paste works ok, though
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.LayerManager
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.GraphicsInterface
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports AcadCOMintf = Autodesk.AutoCAD.ApplicationServices.Application
Inherits System.Windows.Forms.Form
Public AcadApp As AcadApplication
Public AcadDoc As AcadDocument
Public Shared oAcadCOMApp As Autodesk.AutoCAD.Interop.AcadApplication = CType(AcadCOMintf.AcadApplication, AcadApplication)
Private Sub ListLayerStates()
Try
Dim oAcadCOMDoc As Autodesk.AutoCAD.Interop.AcadDocument
oAcadCOMDoc = oAcadCOMApp.ActiveDocument
Dim lsDict As AcadDictionary = oAcadCOMDoc.Layers.GetExtensionDictionary.Item("ACAD_LAYERSTATES")
Dim Xrec As AcadXRecord
For Each Xrec In lsDict
lstLayerStates.Items.Add(Xrec.Name)
Next
Catch acadex As Autodesk.AutoCAD.Runtime.Exception
MsgBox(acadex.Message)
End Try
End Sub
”Boost
