.NET
list dot paired to form
6 REPLIES 6
dolives
661 Views, 6 Replies
I try to make a form with à list dot paired:
(("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0"))
A simple form with 2 column and a windows not fix, expandable !
My problem how to transfert list to .net (VB) ?
Daniel OLIVES
(Sorry for my poor english a french user !)
6 REPLIES 6
_gile
in reply to: dolives
Salut,
Comment to code obtient-il cette liste, depuis un LISP ?
How do your code get this list, from a LISP ?
Gilles Chanteau
GileCAD
GitHub
Hallex
Have you tried Dictionary(of string,string) or something else
Try this out
  Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim dict As Dictionary(Of String, String) = New Dictionary(Of String, String)
            dict.Add("mscorlib.dll", "2.0.0.0")
            dict.Add("AcdbMgd.dll", "18.0.0.0")
            For Each key As String In dict.Keys
                ed.WriteMessage(vbLf + "{0}" + vbTab + "{1}", key, dict(key))
            Next
~'J'~
arcticad
in reply to: Hallex
http://www.dotnetperls.com/keyvaluepair-vbnet
(defun botsbuildbots() (botsbuildbots))
dolives
Thank you very much !
Daniel OLIVES
dolives
in reply to: _gile
Hi Gile,
Yes the list is create form lisp code, i try to just put it in a form i, dot net !
daniel OLIVES
_gile
If I don't misunderstand, you build a LispFunction which an argument is dotted pair list, for example:
(foo '(("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0")))
Your NET code will get the argument as a ResultBuffer (a collection of TypedValues). For the upper example the ResultBuffer will contain these TypedValues where the first item (TypeCode) is a value of the LispDataType enum.
For example, this LispFunction Method:
        [LispFunction("foo")]
        public TypedValue foo(ResultBuffer resbuf)
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            if (resbuf == null)
                return new TypedValue((short)LispDataType.Nil);
            else
                foreach (TypedValue tv in resbuf)
                    ed.WriteMessage("{0} : {1}\n", tv.TypeCode, tv.Value);
                return new TypedValue((short)LispDataType.T_atom);
with (foo '(("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0"))) will write on command line:
5016 : -1
5016 : -1
5005 : mscorlib.dll
5005 : 2.0.0.0
5018 : -1
5016 : -1
5005 : AcdbMgd.dll
5005 : 18.0.0.0
5018 : -1
5017 : -1
5016 => LispDataType.ListBegin
5005 => LispDataType.Text
5018 => LispDataType.DottedPair
5017 => LispDataTypeListEnd
Care, if your dotted pairs have a key/value corresponding to valid TypedValues (DxfCode and a corresponding value) it will be seen by .NET as a single TypedValue.
(foo '((0 . "INSERT") (10 0.0 0.0 0.0) (66 . 1)))
will print:
5016 : -1
0 : INSERT
10 : (0,0,0)
66 : 1
5017 : -1
I expect it helps. Feel free to post on a French speaking forum we both de more comfortable.
Gilles Chanteau
GileCAD
GitHub
”Boost
