I am trying to do something complicated.
It will be similar to the following command sequence. (AutoCAD 2010)
pe (pedit)
m (multi select)
all (select all)
y (convert to polylines)
0 (set fuzzy 0)
j (join)
(done)
s (spline)
(done)
c (close)
(done)
(done)
But instead of "select all", I want to select the entities in the certain layer (this layer will only contain line entities)
I do not think SendStringToExcute() method can do such filtered selection in the middle of command sequence.
So I tried to look for a managed class method that does the "pedit" command. (No clue yet.)
So I am asking for your help.
Is there way to do such work (with C# ObjectARX 2010)?
It would be appreciated if someone can give me some code snippet.
Solved by Hallex. Go to Solution.
Try to search for CommandLine.cs written by Tony Tanzillo
~'J'~
Thx for you reply.
It seems like Tony's CommandLine.cs is easy-to-use method for SendStringToExecute().
It still does not let me to do filtered selection (or quick selection) in the middle of my command sequence. 😞
Is there one line command for filtered selection or quick selection? (without the option dialogue. when I type "filter" or "qselect" a dialogue pops-up)
Here is a quick sample how to use CommandLine.cs to join:
[CommandMethod("JoinLayer","JL", CommandFlags.UsePickSet)] public static void Test() { Database db = HostApplicationServices.WorkingDatabase; Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; string layer = ed.GetString("\nEnter layer name: ").StringResult; string ctab= Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString(); using (Transaction tr = db.TransactionManager.StartTransaction()) { PromptSelectionOptions pso = new PromptSelectionOptions(); pso.MessageForRemoval = "\nNothing selected"; pso.MessageForAdding = "\nSelect lines and/or arcs only:"; TypedValue[] tvs = new TypedValue[] { new TypedValue(0, "line,arc"), new TypedValue(8, layer), new TypedValue(410, ctab) }; PromptSelectionResult pres = ed.SelectAll(new SelectionFilter(tvs)); if (pres.Status != PromptStatus.OK) return; SelectionSet ss = pres.Value; int res = CommandLine.Command ("._PEDIT", "_m", "_p", "", "_y", "_join", "", ""); ed.Regen(); tr.Commit(); } }
Change to your suit
~'J'~
Ah ha~!!
select -> p
does the trick I need~!! 😃
You are always awesome.
Thank you very much.
Sincerely,
Jake
You're welcome, Jake
Thanks to Tony Tanzillo
~'J'~
