.NET
.NET
Valued Contributor
3 Kudos
Post 1 of 6
Lines to Closed Polylines to Spline
311 Views, 5 Replies
08-01-2012 02:43 AM
I am trying to do something complicated.
It will be similar to the following command sequence. (AutoCAD 2010)
pe (pedit)
m  (multi select)
all (select all)
y (convert to polylines)
0 (set fuzzy 0)
j (join)
(done)
s (spline)
(done)
c (close)
(done)
(done)
But instead of "select all", I want to select the entities in the certain layer (this layer will only contain line entities)
I do not think SendStringToExcute() method can do such filtered selection in the middle of command sequence.
So I tried to look for a managed class method that does the "pedit" command. (No clue yet.)
So I am asking for your help.
Is there way to do such work (with C# ObjectARX 2010)?
It would be appreciated if someone can give me some code snippet.
Here is a quick sample how to use CommandLine.cs to join:
 [CommandMethod("JoinLayer","JL", CommandFlags.UsePickSet)]
public static void Test()
Database db = HostApplicationServices.WorkingDatabase;
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
string layer = ed.GetString("\nEnter layer name: ").StringResult;
string ctab= Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString();
using (Transaction tr = db.TransactionManager.StartTransaction())
PromptSelectionOptions pso = new PromptSelectionOptions();
pso.MessageForRemoval = "\nNothing selected";
pso.MessageForAdding = "\nSelect lines and/or arcs only:";
TypedValue[] tvs = new TypedValue[] { new TypedValue(0, "line,arc"), new TypedValue(8, layer), new TypedValue(410, ctab) };
PromptSelectionResult pres = ed.SelectAll(new SelectionFilter(tvs));
if (pres.Status != PromptStatus.OK) return;
SelectionSet ss = pres.Value;
int res = CommandLine.Command ("._PEDIT", "_m", "_p", "", "_y", "_join", "", "");
ed.Regen();
tr.Commit();
 Change to your suit
~'J'~
171 Kudos
Post 2 of 6
Re: Lines to Closed Polylines to Spline
08-01-2012 03:55 AM in reply to: dynamicscope
Try to search for CommandLine.cs written by Tony Tanzillo
~'J'~
Valued Contributor
3 Kudos
Post 3 of 6
08-01-2012 04:47 AM in reply to: Hallex
Thx for you reply.
It seems like Tony's CommandLine.cs is easy-to-use method for SendStringToExecute().
It still does not let me to do filtered selection (or quick selection) in the middle of my command sequence. :smileysad:
Is there one line command for filtered selection or quick selection? (without the option dialogue. when I type "filter" or "qselect" a dialogue pops-up)
171 Kudos
Post 4 of 6
08-01-2012 05:35 AM in reply to: dynamicscope
                                  ed.Regen();
                                  tr.Commit();
 Change to your suit
~'J'~
Valued Contributor
3 Kudos
Post 5 of 6
08-01-2012 10:49 PM in reply to: Hallex
Ah ha~!!
select -> p
does the trick I need~!! =)
You are always awesome.
Thank you very much.
Sincerely,
Jake
171 Kudos
Post 6 of 6
08-02-2012 05:17 AM in reply to: dynamicscope
You're welcome, Jake
Thanks to Tony Tanzillo :smileyhappy:
~'J'~
