.NET
Lines to Closed Polylines to Spline
5 REPLIES 5
dynamicscope
744 Views, 5 Replies
I am trying to do something complicated.
It will be similar to the following command sequence. (AutoCAD 2010)
pe (pedit)
m  (multi select)
all (select all)
y (convert to polylines)
0 (set fuzzy 0)
j (join)
(done)
s (spline)
(done)
c (close)
(done)
(done)
But instead of "select all", I want to select the entities in the certain layer (this layer will only contain line entities)
I do not think SendStringToExcute() method can do such filtered selection in the middle of command sequence.
So I tried to look for a managed class method that does the "pedit" command. (No clue yet.)
So I am asking for your help.
Is there way to do such work (with C# ObjectARX 2010)?
It would be appreciated if someone can give me some code snippet.
5 REPLIES 5
Hallex
in reply to: dynamicscope
Try to search for CommandLine.cs written by Tony Tanzillo
~'J'~
dynamicscope
in reply to: Hallex
Thx for you reply.
It seems like Tony's CommandLine.cs is easy-to-use method for SendStringToExecute().
It still does not let me to do filtered selection (or quick selection) in the middle of my command sequence. 😞
Is there one line command for filtered selection or quick selection? (without the option dialogue. when I type "filter" or "qselect" a dialogue pops-up)
Hallex
Here is a quick sample how to use CommandLine.cs to join:
       [CommandMethod("JoinLayer","JL", CommandFlags.UsePickSet)]
                          public static void Test()
                              Database db =  HostApplicationServices.WorkingDatabase;
                              Editor ed =    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
                              string layer = ed.GetString("\nEnter layer name: ").StringResult;
                 string ctab= Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ctab").ToString();
                              using (Transaction tr =  db.TransactionManager.StartTransaction())
                                  PromptSelectionOptions pso = new    PromptSelectionOptions();
                                  pso.MessageForRemoval = "\nNothing selected";
                                  pso.MessageForAdding = "\nSelect lines and/or arcs only:";
                                  TypedValue[] tvs = new TypedValue[] { new TypedValue(0, "line,arc"), new TypedValue(8, layer), new TypedValue(410, ctab) };
                                  PromptSelectionResult pres =   ed.SelectAll(new SelectionFilter(tvs));
                                  if (pres.Status != PromptStatus.OK) return;
                                  SelectionSet ss = pres.Value;
                                  int res = CommandLine.Command  ("._PEDIT", "_m", "_p", "", "_y", "_join", "", "");
                                  ed.Regen();
                                  tr.Commit();
 Change to your suit
~'J'~
dynamicscope
in reply to: Hallex
Ah ha~!!
select -> p
does the trick I need~!! 😃
You are always awesome.
Thank you very much.
Sincerely,
Jake
Hallex
You're welcome, Jake
Thanks to Tony Tanzillo Smiley Happy
~'J'~
”Boost
