.NET
Lines are Too thick in PDF Conversion File
14 REPLIES 14
Message 1 of 15
42167 Views, 14 Replies
Hi all,
I have Code which creates PDF for the preferred layout using Adobe PDF. But problem is lines in the pdf conversion file is very thick and also the text when we zoom inside. Can anyone help me is there any settings that i need to do. i have done tried all the ways. Done with LWDISPLAY = off, LWT = off.
Please help me...
Thanks in advance.
14 REPLIES 14
Message 2 of 15
I am assuming your using the DWG To PDF.pc3 Plotter.
If so, what version of AutoCAD are you running. I've had problems in the past using this plotter in 2009 with thick lineweights, but that has since been fixed in 2010.
Message 3 of 15
I m using AutoCAD 2006. and using Adobe PDF as Plotter/printer name.
Any suggestions please..
Message 4 of 15
Unfortunately I haven't had the luxury of dealing with Adobe stuff.
If there isn't anything under it's settings thats obvious and you are plotting the correct pen settings/thicknesses than I would suggest taking a look on the Adobe forums.
Message 5 of 15
Hi divya,
This is Sravanthi.Can you help me in writing a program that Converts DWG to PDF in Vb.NET. I am new to ACAD and stuff. Looking forward to it.
Message 6 of 15
AlexFielder
Hi Divya, I have done some work with AutoCAD 2006 and printing .dwg files using Adobe PDF - I think the problem stems from scaling lineweights (or not scaling them - I forget which).
If this doesn't help you, I'll try and dig out the vba code we used for it.
Message 7 of 15
We see this in DWF and PDF when the page size is being shrunk. For example,
if you plot a 24x36 layout to 11x17 PDF or DWF, all weights are too thick.
The options are:
1. don't shrink the page - create PDF and DWF at the same page size (eg.
24x36)
2. create a new layout with the layout page size set to the same size as
your PDF or DWF needs to be
Scale lineweights might work - I have never tried it.
Message 8 of 15
jeffl
Here's what I do, if it helps.
Create pdf and/or dwf to full size, ie 22 x 34, for us. Print on 11 x 17 at a scale factor of 50% for reductions. This way they are still to a scale.
Scale lineweights, scales ALL lineweights down to the same scale, ie all lines are the same thickness, skinny.
Jeff
Jeff Leeman, C.E.T.
Message 9 of 15
ssx_Autodesk
if you're using the Adobe PDF System printer (and not a pc3 file), then why not try a different PDF engine - I've used PDF Creator for years and it works well.
http://sourceforge.net/projects/pdfcreator/
the other question would be if you are using color tables or styles for your lineweights. i've always used color tables (.ctb files) and have had no problems with making PDFs from DWGs.
Message 10 of 15
divyasree, can you post your code ?
Message 11 of 15
i solved my problem, exactly the same
well its a 2009 question but my still asking it 2013.
what i diid was copy the entire workshhet and paste it on a freshly opened cad and safe as
the printing problem should be fixed
regards
Message 12 of 15
Copy the worksheet and open a fresh CAD window and paste it on the new window.
that should solve it.
Message 13 of 15
copy and paste your work into a fresh CAD window, that should solve it.
Message 14 of 15
swaywood
hi,divyasree
i am looking forward the plot method using 'adobe pdf.pc3', could you kindly send me your code then i can study from you.
you know, we usally want to create pdf file without showing the 'save pdf' dialog and directly using the program define file name and file path, if this can be realize, we can plot dwg silently, that's a great thing!
Message 15 of 15
roseanneevangelista
Mine worked.. lines turned to their normal lineweights, when I "UNCHECKED" the "scale lineweights" box just above the Apply to layout button on the Print setup.Cat Very Happy
Hope this may work to all same cases!
”Boost
