.NET
Active Contributor
2 Kudos
Post 1 of 4
Line intersect with block
396 Views, 3 Replies
03-20-2013 01:38 AM
Hi All,
I find the intersected point of Line and block as this code:
'bref is a block reference
Dim tmpLine As New Line(pt1, bref.Position)
Dim ptCol As New Point3dCollection
bref.IntersectWith(tmpLine, Intersect.OnBothOperands, ptCol, 0, 0)
Dim acLine As New Line(pt1,ptCol(0))
 But the intersected point is not located on block as picture below. I don't know what happen.
Thank you for any help.
Easiest way is explode BlockRerence (method BlockReference.Explode but without adding entities to Database) and then intersect your's line with every entity in collection of exploded entities (maybe recursive if entity in collection is also BlockReference).
Moderator
277 Kudos
Post 2 of 4
Re: Line intersect with block
03-20-2013 06:27 AM in reply to: ditran
It is look like you found intersect point which on bounding box of block reference:
Intersecting any entity with a BlockReference and retrieving the intersection points
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
2 Kudos
Post 3 of 4
03-20-2013 06:48 AM in reply to: ditran
I found the intersecting point of line and bounding box of block reference. Can you help me with VB.net code.
Moderator
277 Kudos
Post 4 of 4
03-20-2013 07:01 AM in reply to: ditran
