.NET
Layout units?
2 REPLIES 2
258 Views, 2 Replies
Layout units?
OK, first off this IS a request for a .net equivalent to a vba tool (or
option/setting if you prefer).
In VBA I used this to determine the units (Metric or imperial)..
ThisDrawing.PaperSpace.Layout.PaperUnits
I've found a few settings that "seem" to be what I'm after but so far
they aren't working so I must be barking up the wrong tree.
Can someone please tell me what I need to use to get this info in .NET?
One side note, yes I do realize .NET is not the same as VBA (hence why
I am here asking).
Work: VISTA Ultimate x32 - AMD 64 X2
Dual Core 4200 2.2GHz, 4 Gigs Ram, GeForce
6800GS 256MB
Home: VISTA Ultimate x64 - AMD 64 Quad
Core 2.2GHz, 8 Gigs Ram, GeForce 8600GT 512MB
Laptop (17" HP): VISTA Premium x32 -
color="#000000">AMD Turion X2 Dual Core TL-50 1.6GHz, 2 Gigs Ram,
color="#666666">Nvidia GeForce 6150
2 REPLIES 2
bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
btrSpace = trans.GetObject(bt(BlockTableRecord.PaperSpace), OpenMode.ForRead)
Dim lay As Layout = trans.GetObject(btrSpace.LayoutId, OpenMode.ForRead)
Dim unit As PlotPaperUnit = lay.PlotPaperUnits
should get you close...
jvj Edited by: JamieVJohnson on Dec 17, 2008 12:56 PM
Thank you!
That is exactly what I was after (looks like I was close..  the whole
"plotpaperunits"..  just didn't know how to use it.
Thank you again.
Work: VISTA
Ultimate x32 - AMD 64 X2 Dual Core 4200 2.2GHz, 4 Gigs Ram,
color="#666666">GeForce 6800GS 256MB
JamieVJohnson wrote:
bt =
OpenMode.ForRead)
jvj
”Boost
