.NET
layers in new database
13 REPLIES 13
Message 1 of 14
kob4lt
1207 Views, 13 Replies
Can I create a new layer and then add a few entities in that layers in newly created database?
Somethink like this
private void DodavanjePoligona(ref Database newDB, string imeLayera, Point2dCollection tockeCestica)
            Random random = new Random();
            //using (DocumentLock doclock = doc.LockDocument())
                using (Transaction trans = newDB.TransactionManager.StartTransaction())
                    LayerTable layerKolekcija = trans.GetObject(newDB.LayerTableId, OpenMode.ForRead) as LayerTable;
                    if (layerKolekcija.Has(imeLayera) == false)
                        LayerTableRecord ltr = new LayerTableRecord();
                        ltr.Color = Color.FromRgb((byte)random.Next(255), (byte)random.Next(255), (byte)random.Next(255));
                        ltr.Name = imeLayera;
                        layerKolekcija.UpgradeOpen();
                        layerKolekcija.Add(ltr);
                        trans.AddNewlyCreatedDBObject(ltr, true);
                    BlockTableRecord btr = trans.GetObject(newDB.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                    Polyline cestica = new Polyline();
                    int count = 0;
                    foreach (Point2d toc in tockeCestica)
                        cestica.AddVertexAt(count, toc, 0, 0, 0);
                        count++;
                    try
                        cestica.Layer = imeLayera;
                    catch (Exception ex)
                    btr.AppendEntity(cestica);
                    trans.AddNewlyCreatedDBObject(cestica, true);
                    trans.Commit();
It crashes at try block...
But when I save newDB and open it, I can see that new layers has been created
13 REPLIES 13
Message 2 of 14
kdub_nz
in reply to: kob4lt
How are you calling this ??
Can you post the calling code including the  CommandMethod Attribute Statement
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 14
kdub_nz
in reply to: kdub_nz
Just for fun - current document ;
[CommandMethod("Test101001")]
public void Test101001()
    Database db = AcadApp.DocumentManager.MdiActiveDocument.Database;
    string layerName;
    Point2dCollection pts = new Point2dCollection();
    pts.Add(new Point2d(0.0, 0.0));
    pts.Add(new Point2d(150.0, 0.0));
    pts.Add(new Point2d(150.0, 100.0));
    pts.Add(new Point2d(0.0, 200.0));
    layerName = "TestLayer_1";
    DodavanjePoligona(ref db, layerName, pts);
    pts.Clear();
    pts.Add(new Point2d(20.0, 20.0));
    pts.Add(new Point2d(170.0, 20.0));
    pts.Add(new Point2d(170.0, 120.0));
    pts.Add(new Point2d(20.0, 220.0));
    layerName = "TestLayer_2";
    AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nDone: ");
 and - new Document ;
[CommandMethod("Test101003"CommandFlags.Session)]
public void Test101003()
    // Create a new document database
    DocumentCollection docMgr = Application.DocumentManager;
    Document acNewDoc = docMgr.Add("acadiso.dwt");
    Database acDbNewDoc = acNewDoc.Database;
    string layerName;
    // Lock the new document
    using (DocumentLock acDocLock = acNewDoc.LockDocument())
        DodavanjePoligona(ref acDbNewDoc, layerName, pts);
    } // Unlock the document
    pts.Clear();
        pts.Clear();
        pts.Add(new Point2d(40.0, 40.0));
        pts.Add(new Point2d(190.0, 40.0));
        pts.Add(new Point2d(190.0, 140.0));
        pts.Add(new Point2d(40.0, 240.0));
        layerName = "TestLayer_3";
    // Set the new document current
    docMgr.MdiActiveDocument = acNewDoc;
Message 4 of 14
kdub_nz
Just a side note:
You may be best to add a functional statement to the catch rather than leave it empty.
Random objects that are instantiated in close succession generate an identical series of random numbers ...
So,
If you really want random colors for your layers it may be best to generate the Random object once in the calling routine and re-use it for each call to the DodavanjePoligona
Message 5 of 14
kob4lt
This method is calling from a button on form and form is calling like this
[CommandMethod("energo")]
        public void energo()
            EnergoForma FormaEnergometana = new EnergoForma();
            FormaEnergometana.Show();
 and the calling method
DodavanjePoligona(ref newDB,opcina, kolekcijaTockakaCestice);
Message 6 of 14
kdub_nz
in reply to: kob4lt
What you've posted is very little use for me to help you.
Did the code I posted help at all. ?
Are you locking the document ?
Did you try using
[CommandMethod("myCommand"CommandFlags.Session)]
Message 7 of 14
Jeffrey_H
Also I noticed and if Kerry agree's
 you should consider using
Application.ShowModelessDialog()
or
Application.ShowModalDialog()
You can also find your answers @ TheSwamp
Message 8 of 14
kdub_nz
in reply to: kob4lt
Helllloooooo ...
Anyone home ??
Message 9 of 14
kob4lt
Sorry, I am on a trip right now... I will reply to you as soon as posible
Message 10 of 14
kob4lt
in reply to: kob4lt
Sorry for my delay of answering to you all.
So, here is new code and the same thing is happing in this code
void UbacivanjeObjekataUDB(object[] podaciOObjektu)
            ObjectId idBlocka;
            Point2d tempTocka;
            BlockReference block;
            string data;
            string data1;
            string feature = podaciOObjektu.GetValue(0).ToString();
            using (DocumentLock docLock = doc.LockDocument())
                    BlockTable bt = trans.GetObject(newDB.BlockTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead) as BlockTable;
                    BlockTableRecord btr = trans.GetObject(bt[BlockTableRecord.ModelSpace], Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite) as BlockTableRecord;
                    switch (feature)
                        case "fasadni":
                            if (layerKolekcija.Has(feature) == false)
                                ltr.Name = feature;
                            idBlocka = bt["fas"];
                            tempTocka = (Point2d)podaciOObjektu.GetValue(1);
                            block = new Autodesk.AutoCAD.DatabaseServices.BlockReference(new Autodesk.AutoCAD.Geometry.Point3d(tempTocka.X, tempTocka.Y, 0), idBlocka);
                            block.Layer = feature; /// <--ERROR HERE eKeyNotFound
                            btr.AppendEntity(block);
                            trans.AddNewlyCreatedDBObject(block, true);
                            break;
 I'm not using ModelessDialog and commandFlag.Session
Can someone explain me what is the diference between commandFlags and what should I gain with ModelessDialog form?
Thank you all
Message 11 of 14
kob4lt
in reply to: kob4lt
Do i have to call trans.Commit() so that changes can take effect?
Message 12 of 14
Jeffrey_H
in reply to: kob4lt
Yes you must call Transaction.Commit()
And if you have nested transaction you must call Transaction.Commit() on all outer transaction. For it take effect.
The session command flag executes at the Application Context and you must lock your document, same for modless forms.
If you are working at the documrnt context then AutoCAD will handle locking the document for you.
Open the arxdoc.chm and in the index tab enter "locking" , "application execution contexts", "document execution contexts", and "document locking"   and look at the info under that, for more detailed explanation.
Message 13 of 14
kob4lt
in reply to: Jeffrey_H
I modified like this and it did not work
void KreiranjeLayera(string layer)
                    LayerTable layerKolekcija = trans.GetObject(newDB.LayerTableId, OpenMode.ForWrite) as LayerTable;
                    ltr.Name = layer;
                    trans.Commit();
            ObjectId idBlocka;
            Point2d tempTocka;
            string data;
            string data1;
            bool layerPostoji;
                    switch (feature)
                        case "fasadni":
                            layerPostoji = true;
                                layerPostoji = layerKolekcija.Has(feature);
                            if (!layerPostoji)
                                KreiranjeLayera(feature);
                            break;
it is funny but after I create layer and I ask LayerTable if it has that layer it says true but when I tried to attach that layer on some object it failes on this code "block.Layer = feature;"
Message 14 of 14
jamierobertson1
in reply to: kob4lt
I had this problem as well, Not sure why. I noticed that if I set the layer current with Dababase.Clayer and just added entites, they went into the new layer ok.
”Boost
