.NET
0 Kudos
Post 1 of 5
Layer Manager Not Updated
179 Views, 4 Replies
07-17-2012 01:32 PM
What would cause a layer manager to NOT be updated after code has been run to freeze or thaw layers in a viewport?  After I run my program, the viewports will show the layers I want thawed and will hide the layers I want frozen, but when you look at the layer manager, it would show all layers are on and thawed.
If you save the drawing, close it and re-open it, the layer manager now seems fine and matches the viewports as to what is thawed and what is frozen.
I would appreciate any info on what would cause this.  Also, I can post my code if interested.
Valued Mentor
28 Kudos
Post 2 of 5
Re: Layer Manager Not Updated
07-17-2012 02:25 PM in reply to: mgorecki
hi
can you past your code ?
Have you commit your transaction  ?
Valued Mentor
53 Kudos
Post 3 of 5
07-17-2012 05:11 PM in reply to: AubelecBE
Try adding a new layer and see what happens
http://www.theswamp.org/index.php?topic=42239.0
You can also find your answers @ TheSwamp
0 Kudos
Post 4 of 5
07-18-2012 08:12 AM in reply to: jeff
0 Kudos
Post 5 of 5
07-20-2012 02:59 PM in reply to: mgorecki
Ok, just installed the Service Pack 2 for AutoCad 2010.  That fixed the Layer Manager freeze/thaw issue.
