.NET
Layer creation error
3 REPLIES 3
161 Views, 3 Replies
Does anyone have a question why this would be erroring at this point;
"im lt As LayerTable = tm.GetObject(db.LayerTableId, OpenMode.ForWrite, True)"
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim tm As DBTransMan = db.TransactionManager
'start a transaction
Dim myT As Transaction = tm.StartTransaction()
Dim ltr As LayerTableRecord = New LayerTableRecord
ltr.Name = namLay
Dim myColor As New Color()
myColor.ColorIndex() = colLay
ltr.Color() = myColor
If Linetype <> "Continuous" Then ltr.LinetypeObjectId = CheckForLineType(Linetype)
MsgBox("5")
Dim lt As LayerTable = tm.GetObject(db.LayerTableId, OpenMode.ForWrite, True)
lt.Add(ltr)
tm.AddNewlyCreatedDBObject(ltr, True)
ltr.Description = Descrip
myT.Commit()
tm.Dispose()
3 REPLIES 3
Autocad 2005 only
NathTay
You are using the transaction manager to get the table instead of the transaction.
Try changing
to
Dim lt As LayerTable = myT.GetObject(db.LayerTableId, OpenMode.ForWrite, True)
Regards - Nathan
It tried your suggestions and still same error...I evn tried autodesk layer create example for 2005 and still get this error
”Boost
