.NET
Hallex
Message 11 of 13 (142 Views)
Re: Layer Convertion Project for .NET
02-23-2012 12:27 AM in reply to: bryan.thomasy
I added possibility to check if the plotstyle is exist in your document
{code}
       <CommandMethod("IMRColors", CommandFlags.Modal + CommandFlags.Session)> _
        Public Sub STBTest()
            If Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("PSTYLEMODE") = 1 Then
                MsgBox("Drawing is not STB")
                Exit Sub
            End If
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim how As Boolean = False
            Dim pltStyles As List(Of String) = New List(Of String)({"Black", "DGray", "MGray", "LGray", "White", "Normal"})
            Using doclock As DocumentLock = doc.LockDocument
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Dim ltTable As LayerTable = tr.GetObject(db.LayerTableId, OpenMode.ForRead)
                    Try
                        Dim pstDict As DictionaryWithDefaultDictionary = tr.GetObject(db.PlotStyleNameDictionaryId, DatabaseServices.OpenMode.ForRead)
                        For n As Integer = 0 To pltStyles.Count - 1
                            Dim pltSt As String = pltStyles(n)
                            If Not pstDict.Contains(pltSt) = True Then
                                MsgBox("PlotStyle """ + pltSt + """ does not exist. Program Exiting")
                                Return
                            End If
                        Next
                        For Each ltID As ObjectId In ltTable
                            Dim ltRec As LayerTableRecord = tr.GetObject(ltID, OpenMode.ForWrite)
                            If ltRec.IsLocked Then
                                MsgBox(ltRec.Name + " is locked. it will be unlocked")
                                ltRec.IsLocked = False
                            End If
                            Dim i As Double
                            i = 0
                            Dim y As Integer
                            y = 0
                            Dim sPlotStyleName As String
                            sPlotStyleName = ltRec.PlotStyleName
                            Dim cLayerColor As Color
                            cLayerColor = ltRec.Color
                            Dim sLayerColor As Short
                            sLayerColor = cLayerColor.ColorIndex
                            Dim cLineweight As LineWeight
                            cLineweight = ltRec.LineWeight
                            Select Case sLayerColor
                                Case 1, 15 To 30, 230 To 239
                                    ltRec.PlotStyleName = "Black"
                                    ltRec.LineWeight = LineWeight.LineWeight009
                                Case 2, 31 To 59
                                    ltRec.LineWeight = LineWeight.LineWeight050
                                Case 3, 60 To 129
                                    ltRec.LineWeight = LineWeight.LineWeight018
                                Case 7, 240 To 249
                                    ltRec.LineWeight = LineWeight.LineWeight025
                                Case 6, 180 To 229
                                    ltRec.LineWeight = LineWeight.LineWeight030
                                Case 4, 5, 130 To 179
                                    ltRec.LineWeight = LineWeight.LineWeight040
                                Case 10
                                Case 11
                                    ltRec.LineWeight = LineWeight.LineWeight070
                                Case 12
                                    ltRec.LineWeight = LineWeight.LineWeight080
                                Case 13
                                    ltRec.LineWeight = LineWeight.LineWeight090
                                Case 14
                                    ltRec.LineWeight = LineWeight.LineWeight120
                                Case 8
                                    ltRec.PlotStyleName = "LGray"
                                Case 9
                                    ltRec.LineWeight = LineWeight.LineWeight015
                                Case 251
                                    ltRec.LineWeight = LineWeight.LineWeight020
                                Case 252
                                    ltRec.PlotStyleName = "MGray"
                                Case 253
                                Case 255
                                    ltRec.LineWeight = LineWeight.LineWeight140
                                Case 254, 250
                                    ltRec.PlotStyleName = "White"
                                Case Else
                                    ed.WriteMessage(ltRec.Name & " was not altered" & vbCrLf)
                                    i = i + 1
                            End Select
                        Next
                        tr.Commit()
                        how = True
                    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                        Dim y As Integer = 0
                        If ex.Message Like "Key Not Found*" And y < 30000 Then
                            Dim oPoint As DBPoint = Nothing
                            Dim dLoc As Double() = New Double(2) {}
                            dLoc(0) = 5.0
                            dLoc(1) = 5.0
                            dLoc(2) = 0.0
                            Dim crnSP As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                            crnSP.AppendEntity(oPoint)
                            tr.AddNewlyCreatedDBObject(oPoint, True)
                            oPoint.PlotStyleName = "Black"
                            oPoint.PlotStyleName = "DGray"
                            oPoint.PlotStyleName = "MGray"
                            oPoint.PlotStyleName = "LGray"
                            oPoint.PlotStyleName = "White"
                            oPoint.PlotStyleName = "Normal"
                            oPoint.Erase()
                            y = y + 1
                        Else
                            MsgBox("Something went wrong " + Err.Description & ", that sounds awful")
                            Return
                        End If
                        ed.WriteMessage(ex.Message)
                        how = False
                    Finally
                        Dim result As String = "   ---   The IMRColors program has ended up with " + IIf(how, "success", "some bugs").ToString
                        ed.WriteMessage(vbLf + result)
                    End Try
                End Using
            End Using
        End Sub
{code}
~'J'~
bryan.thomasy
Message 12 of 13 (133 Views)
02-23-2012 05:34 AM in reply to: bryan.thomasy
That was above and beyond..!!  Thank you.  I shall have to try it out...
Hallex
Message 13 of 13 (123 Views)
02-23-2012 08:38 AM in reply to: bryan.thomasy
Let me know if you need  some other stuffs
on this way
Oleg
~'J'~
